Originally posted by boriscleto You can change the Program Line on the high end cameras like the K-3 or K-1, but not on the KS-2.
This is true as to changing the nature of the Program Line. But simply by using the thumb and finger e-dials when in P mode, with the K-S2 you can instantly switch to either Tv or Av program modes if you wish to over-ride the camera's auto-choice of aperture or shutter speed when in P mode, and select your own value instead, without having to change the mode dial first to Av or to Tv. A touch of the green button restores the fully-automated P operation. The green button is also very useful when in (Hyper) M mode, for taking fast, efficient meter-readings, getting an instant meter-centered exposure setting, and is especially efficient for taking spot meter readings around a scene. The K-S2 is equipped for full use of the Pentax Hyper System, and the lens being discussed is fully compatible also.
