04-12-2018, 06:40 AM   #1
AF button K3ii
When using the AF button to focus (back button focusing). do I have to hold the AF button if I want to recompose after I focus.
04-12-2018, 06:56 AM   #2
In general no, you can release it.
If your subject is moving and you set up AF.C, then you may want to keep pressing the AF button. If you release it, the focus distant remain at where it locked.
04-12-2018, 08:23 AM   #3
jatrax's Avatar
No. When using AF.S once focus is established it stays once you release the button. That is the big advantage of back button focusing. Using the shutter button to focus causes the camera to refocus every time you touch it.
When using AF.C you can focus and release and it will work the same as AF.S but if you hold it down it works as AF.C. For that reason I usually have the camera in AF.C so that if I hold the button down I have AF.C but if I focus and release it functions as AF.S. Best of both worlds. Another advantage of back button focus.
04-12-2018, 09:31 AM   #4
Otis Memorial Pentaxian
QuoteOriginally posted by Charben Quote
It depends on your AF button settings (menu >> record mode 4 >> Button Customization >> AF Button). The default (AF 1) is to enable AF on both shutter half-press the AF button, meaning that if you press the shutter release after the AF button, the camera will focus again. If you change to AF 2, focus will only be done with the back button and focus will be held until you press it again.
af, af button, back button focus, button, camera, focus, pentax help, photography, troubleshooting
Ricoh GRII, camera freezing up with AF button is pushed in C-AF mode. oettammatteo Troubleshooting and Beginner Help 2 10-08-2017 11:58 AM
Decouple AF-L and AE-L when using Back Button in DSLRs without dedicated AF-L buttons anu l Pentax DSLR Discussion 13 04-04-2016 05:08 AM
AF.C (Focus-prority) with the AF button skyer Pentax K-5 & K-5 II 17 04-29-2013 02:20 PM
Green button and AE-L button voyager13 Troubleshooting and Beginner Help 7 06-28-2012 12:26 PM
Green button or +/- button for meter? kidblue Pentax SLR Lens Discussion 15 07-29-2011 07:10 PM
All times are GMT -7. The time now is 02:02 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
