Originally posted by jonathanastro I bought the pentax k-1, I take a lot of night shots, after I bought the camera I went to photograph the Milky Way I had parameters of iso 4500, 20 sec, f 2.8 and the picture came with a lot of noise, I would like to know if the problem is known or it is a configuration problem, the lens I took with it Pentax 15-30 f2.8 I also put the focus to infinity and there were places in the picture that were not in focus
Noise:
Although the K-1 is excellent in low light, to reduce noise, Iʻd suggest not exceeding ISO 3200 for astro photography. Depending on your focal length, the stars will begin to blur due to the Earthʻs rotation starting around 30 seconds. And because the camera has astrotracer, Iʻd highly recommend you learn to use it so you can increase your exposure time while both lowering the ISO while stopping down a bit more to perhaps f/4 or f/5.6 on the 15-30 f/2.8 zoom.
I almost always shoot RAW exclusively, but for astro photography, Iʻd recommend shooting RAW+ jpeg. The K-1 processor can reduce noise really well and unless youʻre experienced with post-processing, the jpeg can often reduce the noise more effectively than the average user with PS or LR.
Focus:
I agree with previous posts here and donʻt trust the infinity mark on the lens. Manually bracket focus at f/2.8 of either shots at great distance (on the horizon or stars). Alternatively if you want to just leave it on the infinity mark, then bracket your AF fine tune in the menu. Try 0, then adjust one for +5 and another at -5. If +5 looks the best, then try +7 and +3, etc, until you find the sweet spot. Leave the focal length set to what you normally shoot the stars with throughout the testing. If you invariably use everything from 15 thru 30mm, then do the tests in the middle around 23mm.
Eliminate the possibility that what is perceived as mediocre focus isnʻt motion blur/camera vibration. Solid tripod without the center column extended. Avoid setting up on pavement as it can transmit vibration from vehicles, etc. Try to set it on terra firma. SR off! Remote trigger/cable release or self timer. Mirror lock up. If there is a remote chance of light entering the viewfinder during exposure, block the viewfinder with anything if you lost your light blocker made for that.
