Originally posted by jatrax Hi Terry,
The shutter button turns on the meter at the half press, (just bump the shutter button a bit) and it stays on for the length of time set in the menu C-3 Meter Operating Time. After that time out you need to bump the shutter button again to turn the meter on again. I assume it uses battery power so they do not want it on all the time, just when you are using it.
Unless you know the differences ( which I suggest you study up on) stick with Matrix Metering. You should understand what the three modes do and be able to choose the best one for each scene but in general use Matrix.
---------- Post added 04-21-18 at 08:34 AM ----------
BBF has nothing to with being rushed, rather it is useful because you only focus when you press the focus button not the shutter button. It separates the 'focusing' function from the 'shutter actuation" function. It removes the risk of your carefully set focus being ruined by the camera trying to autofocus when you finally get around to taking a picture.
Of course if you are manually focusing then it matters little as the AF should turned off.
Thank you, jatrax. I will go into C3 and change the time, before going out today. I didn't realize I could do that. Also, I will Matrix metering. I normally use spot. I probably will end up manual focusing more than I realize. By the time I set up my massive tripod and ball head, I will certainly be taking my time. Why rush doing something you enjoy so much?
Terry
---------- Post added 04-21-18 at 09:47 AM ----------
Originally posted by baro-nite Shake reduction is disabled by default when you use the 2-second self-timer, so you might prefer to leave SR on, so you won't forget to do so when you're shooting hand-held.
Don't worry too much about getting the exposure just right -- shoot in raw format and you'll have enough dynamic range to handle most situations well enough with automatic exposure modes. For working with a tripod you might prefer Av mode (aperture priority) to give you that control over depth of field.
More important is to just get out there and shoot a lot. Subject matter, composition, and quality of light are what make landscape images interesting (or otherwise).
Thank you, baro-nite. I didn't know that. I will turn SR back on, today. I just bought my K-1 in January, so I have a lot to learn. Where in NC do you live? I live in Suffolk, VA, and commuted to Ahoskie to work. Really go people in NC.
Terry
---------- Post added 04-21-18 at 09:56 AM ----------
Originally posted by Bob 256 Hi Terry,
Usually for scenics on a tripod, I take my time and use liveview with manual focus and the LCD magnifier to critically focus. I also use delayed shutter like you mentioned, but sometimes use a small handheld remote to trip the shutter without touching the camera. If the scene is static with little motion, I use the electronic shutter. Not that I have anything against AF, I just like to do it old school and see how good the focus is on my subject of interest. Other times when I'm rushed, I use the optical VF and AF exclusively.
I also like the K-1 HDR feature and enjoy taking some shots using that setting with ADV HDR. Since I shoot DNG + JPEG, I can use the individual DNG HDR files later to tailor the HDR effects as desired with separate HDR software, but the JPEG rendition isn't too bad for in-camera HDR and I can print (with minor tweeking) and hand out those to folks who think they look great. I usually shoot at as low an ISO as is practical but don't go below 200.
Just so personal thoughts for you to ponder.
Hi Bob,
PeterPentax suggested that I try HDR as well. I certainly plan on trying it. I assume it's in the manual, since I don't even know what it is, yet. So much to learn and enjoy. I have been shooting RAW for one month now. That's a whole new learning curve, and I will end up ruining a lot of shots during the process. That's ok, I'm sure most people did when starting.
Terry
---------- Post added 04-21-18 at 10:07 AM ----------
Originally posted by mikeSF These are all great tips and it is certainly important to be comfortable with the technical aspects of the shot. I have nothing to add there.
When approaching landscape photography, the main difference between a snapshot and a thoughtful landscape image is composition. I would encourage you to practice placing elements in the frame including some foreground interest whenever possible. Getting in close to a subject is also useful. in time, you will begin to see how you affect the composition with focal length, depth of field, camera positioning, etc. Have fun!
Hi Mike,
I did learn, from this site, to include something in the foreground, and to get close. Just got my 15-30 last week, and I'm really going to enjoy using it. I have fractures in my back, so it's mostly for tripod use. I guess I overspent on my tripod and ball head, but I chose it with this lens in mind. Plus, I just enjoy using a nice one. For me, Photography has always been just for fun, and enjoy using nice equipment.
Terry
