For the last 5 years or so, Pentax has been the only brand of DSLR, all of whose whose models, regardless of price, feature the more expensive glass pentaprism viewfinders. They also show 100% of the framing you will actually get in your picture. This type of VF is of professional standards. It doesn't get any better, regardless of cost, in the APS-C size sensor. So as it is currently, whether you buy a K-70 or whether you buy a KP, the VF will be of the same quality. Once you get a better VF, you would then likely notice the further improvement in brightness between a lens of f/3.5-6.3 and one of f/1.4 or so.
When in a dark environment, set your camera for center-only spot focus and choose something in the scene having more light on it that is of the same distance of that you wish to train your focus on, even though the better-lit subject itself is not centered right for your shot, then once you focus on that by using the half-press, continue holding that focus with the half-press while you re-position your camera to get the shot you are after, then complete the shutter button press to fire your shot.
The AF assist beam is only good for fairly short distances.
