05-12-2018, 02:55 PM   #1
SMC PENTAX-M 100mm f4 Macro - Aperture Issue - Please help
Hello,
I need some help. I took apart my lens to clean it and a spring has popped off and now is now not applying proper tension so the aperture will not open all the way when I put it back together. Please see attached. Any help would be greatly appreciated. I need to know how the spring goes. I just purchased this today and messed it up putting it back together
Thank you
05-13-2018, 01:26 AM   #2
Argh, that's an awful situation.
Does the black pivot arm thing control the aperture? What about the other pivot arm that can be seen on the left in the second picture? Is there a similar spring on the second one?
Also, it looks like there are a couple of silver arms with pins on them, perhaps the spring is meant to hold one of those?
Obviously the above is all just brain farts, because I'm no expert in servicing lens internals (so far I've pulled apart two and successfully reassembled one).
05-15-2018, 05:15 PM   #3
QuoteOriginally posted by sudo Quote
Appreciate the response. I gave up on fixing it myself and contacted Eric Hendrickson and he thinks he may be able to repair it. It should be arriving to him tomorrow for evaluation. I wish assembly drawings were readily available for this model.
100mm f4 macro, aperture, camera, f4 macro aperture, help, macro aperture issue, pentax help, pentax-m 100mm f4, photography, smc pentax-m 100mm, troubleshooting
Vintage Pentax 100mm Macro F4 vs Modern Canon 100mm Macro F2.8 Digital Asylum Pentax SLR Lens Discussion 10 12-06-2017 05:47 AM
Aperture control problems with variable aperture lenses (with aperture rings) gtxSeries Troubleshooting and Beginner Help 3 09-13-2017 01:11 PM
SMC PENTAX D-FA 100mm WR vs SMC Pentax F 100mm SunnyG. Pentax SLR Lens Discussion 14 09-06-2017 06:13 PM
Oh man, please please please help.... deckroid Photographic Technique 8 07-01-2011 09:08 AM
All times are GMT -7. The time now is 03:49 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
