05-22-2018, 06:48 AM   #1
Pop- up Flash
Hi
I have a K5 and a problem with the pop-up flash. When the flash is open the shutter wont fire and no flash, camera works ok with the flash closed. In the custom menu No 20 (Relese While Charging) the shutter will fire. I have reset custom functions and reset still the flash will not opperate. Help !!!
05-22-2018, 08:30 AM   #2
noblepa's Avatar
QuoteOriginally posted by Michael E Quote
Hi
Have you got the shutter speed set faster than 1/180 sec? Pentax cameras will not fire the flash above that speed.
05-22-2018, 11:03 PM   #3
Thank you ror your reply. No the flash not working at speeds under I/180s. If there is no fix for this fault would an external flash work ?
Regards Michael
05-23-2018, 11:29 PM   #4
pschlute's Avatar
Regards Michael
Sounds like your pop up flash is no longer working.
You should be able to use an external flash on the hotshoe.
camera, custom, fire, flash, pentax help, photography, reset, shutter, troubleshooting
Macro Macro with pop-up flash & snoot JosQ Post Your Photos! 8 08-17-2017 07:13 AM
Flash Duration Measurements for K3D Pop-up Flash AstroDave Flashes, Lighting, and Studio 3 03-11-2017 06:40 AM
Using a of camera third party flash with pop up flash GregYoung Pentax K-3 & K-3 II 4 11-30-2016 09:39 PM
K20D pop-up flash doesn't pop up! ducdao Pentax DSLR Discussion 3 11-29-2011 07:57 AM
K2000 - Pop up flash will not pop up. tkindred Pentax DSLR Discussion 6 08-17-2009 08:54 AM
All times are GMT -7. The time now is 02:29 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
