05-22-2018, 02:33 PM   #1
h4yn0nnym0u5e's Avatar
DFA 24-70 bokeh weirdness
Hi folks
I think this is what was touched on in the PF review as "reported but we didn't see any". Not the easiest of subjects (I managed to blow the highlights in the grass), and would probably only be apparent when pixel peeping or doing a humongous print. This was at 58mm f/2.8, another shot at 48mm f/4 a moment before shows very minor effects, but only because I know what to look for.
So, the overall image:
and as big a 100% crop as I can upload:
Note (a) many little bubbles with central bright dots, (b) similar linear features at the bottom left from brightly-lit branches in the distance, and (c) astonishing weird swirly patterns at the right, presumably as a result of both foreground and background being out of focus.
Has anyone else seen examples of this, and if so do you find that it's also focal-length dependent, or just aperture?
Cheers
Jonathan
05-22-2018, 03:05 PM   #2
These are specular highlights. Different lenses handle these differently. My old Super-Tak 55 /1.8 would blow this image up into a cacaphony of bubble bokeh which some love ajd others detest. Looks like your 24-70 has its own particular rendering. Learn to embrace it and you will he happy.
05-22-2018, 03:19 PM   #3
pschlute's Avatar
You have a very high contrast scene and your 100% crop shows it is not only the grass that is blown. The purple OOF flowers look like they are suffering from flare, maybe this is contributing to the "swirly patterns.
05-22-2018, 06:42 PM - 1 Like   #4
Paul the Sunman's Avatar
Just to be sure: you don't have any filters attached, do you?
05-22-2018, 07:35 PM   #5
There was another thread on this yesterday or two days ago, I believe.
05-23-2018, 02:11 PM   #6
Thanks folks.
Interestingly, I found a very similar-looking effect in the review of the HD Pentax-DA 40mm F2.8 Limited. Yes, I did have a filter fitted, but I'd venture there wasn't one on the 40mm! So, maybe longitudinal CA causing axial colour? I'll have to try a few more variations when I'm next there, at differing settings and without the filter, assuming it's a sunny day. Won't be as pretty without the azaleas and wisteria, though
Time to hunt down the "other thread" of which Adam speaks...
Cheers
Jonathan
05-23-2018, 02:37 PM   #7
amoringello's Avatar
Probably mine;
Circular bokeh with 24-70mm? - PentaxForums.com
05-23-2018, 03:28 PM   #8
QuoteOriginally posted by h4yn0nnym0u5e Quote
I had very strange striation effects in the bokeh on the DA 55-300 a few years ago, which I eventually tracked down to a UV filter I had on it permanently. I have now taken them off all my lenses, including the DA 40 Ltd, though none of the others seemed to cause any issues. It can just be a bad filter.
05-24-2018, 01:51 PM   #9
QuoteOriginally posted by amoringello Quote
Looks plausible! You appear only to have got the bubbles, not the central dot, though.
QuoteOriginally posted by Paul the Sunman Quote
Yes, I'll definitely try without the filter, when I have a chance to do a bit of investigation.
Thanks again folks - looks like it's nothing to worry about, just to watch out for if the conditions may provoke it.
06-01-2018, 03:53 PM   #10
Yeah, that is strange. There is only certain photos with certain light that seems to cause the effect.
It would be interesting if the filter or something else is making the effect on yours different. Or if it is a quality/consistency control issue between lenses.
I shoot dog photos, mainly, and only sometimes does the nose reflect this way.
A lot merely down res'd to jpegs for Facebook and the issue isn't usually noticeable.
I will feel ill if I have to blow one of those up to 30x40 for a customer.
Although honestly, I don't know if most non-photographers would even notice.
camera, dfa 24-70 bokeh, pentax help, photography, troubleshooting
For Sale - Sold: Pentax K-1, Pentax DFA 24-70mm 2.8 Lens, Pentax DFA 100mm 2.8 WR Macro Lens 1434 Sold Items 8 05-10-2018 04:54 AM
Dilemma: Portrait Shooting between DFA 24-70 or DFA 70-200 Gerard_Dirks Pentax SLR Lens Discussion 22 10-05-2017 04:34 PM
DFA 24-70 or DFA 15-30 for the K-1? Hattifnatt Pentax SLR Lens Discussion 42 10-25-2016 08:03 AM
K-mount Ricoh kr-30sp light meter weirdness barchaetone Troubleshooting and Beginner Help 8 07-07-2016 09:19 PM
Misc 100mm f/2.8 Macro WR Bokeh Bokeh Bokeh! iocchelli Post Your Photos! 3 03-20-2011 02:22 AM
All times are GMT -7. The time now is 08:36 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
