Originally posted by jawats My K-3 seems off - when I put it in any of the "_v" modes, they ALL say "Aperture Priority" - has the camera become "deprogrammed" from what the other modes should be?
That is how it works, though it is poorly documented. The rules go something like this:
- When the camera is not able to detect a lens that it can control the aperture on, all modes except M, X, and B default over to Av mode. Detection is done through the contacts on the lens mount, specifically the so-called "A" contact. Metering in this case is limited to center-averaged and spot modes.
- Manual aperture lenses may be used in Av mode with the camera metering the shutter speed based on the light hitting the sensor. (The body does not care whether the lens is open or closed. It meters the light, not the number.)
- K mount lenses that set aperture using the aperture ring may also be used in Av mode only with the understanding that both metering and exposure will be made with the lens wide open. If one wants this class of lens to stop down for exposure, one must use M, X, or B modes.
- M mode supports full manual exposure for all K-mount and adapted lenses, but only provides open-aperture metering when the body controls the aperture (A, F, FA, DA, and D FA series lenses)
- When the aperture is set using the aperture ring in M mode, one may use an external meter, an educated guess (so-called sunny 16 estimation), or one of two forms of stop-down through-the-lens metering
- Green button metering is similar to using the green button with the body controlling the aperture except that the camera stops down the lens momentarily for a meter reading and sets the shutter speed appropriately. Green button metering also works in live view
- Stop-down metering in M mode may also be done using the optical DOF preview lever. When this is done, the lens is stopped down and the camera provides an EV scale in the viewfinder and other displays
- Both of the above methods work nicely with manual aperture lenses, though the lens must be stopped down before metering and for exposure
- Exposure compensation and bracketing both work for stop-down metering
- Auto ISO is not available in M mode
- None of the stop-down methods (Av, green button, or DOF preview) are particularly consistent when using the optical viewfinder's meter. One may expect significant and predictable but non-linear exposure variance for most aperture settings on most lenses. This is not a matter of simply dialing in one or two stops EC.
- Green button metering in live view is essentially comparable to open-aperture readings done in live view
Metering methods by order of improved consistency and accuracy go like this: Av mode, M mode (optical viewfinder), M mode (live view), and external meter with the last two being equivalent. This is my personal experience and as a result, I seldom use Av mode with my M42 lenses. It is simply too fiddly.
Originally posted by jawats I think I got all of that except for the part after "Vintage" and before "bodies." But other than that, I am good. :P
Sorry to read this. It may be worth a quick read through again, after looking at the list immediately above. Understanding how and when a lens stops down is one the keys to using vintage lenses on your K-3II and also helps with vintage lens purchases.
Originally posted by jawats But, in all seriousness, it seems least troublesome to set the thing to a couple stops down (say, 5+) and work with ISO and shutter speed to achieve the desired image.
Good luck. You will be doing a lot of chimping. Some lenses will meter overexposure varying by aperture while others will start with underexposure, switch to overexposure and switch back to underexposure as aperture narrows. Fast lenses tend to be worse. What I usually suggest is to spend some time playing with the camera and seeing how it behaves and how to make stop-down metering work for you. I had the benefit of over a decade doing stop-down metering in my youth and doing the same on my K10D and now my K-3 came fairly naturally. What was harder was dealing with the metering inconsistency on the K10D for seven years and learning to use the somewhat improved system on the K-3 for the last four years. Oh, and yes, there is often a fair amount of chimping involved.
This post is turning out to be much more wordy than I intended, but I can leave with one last piece of advice. In addition to my K-3, I also shoot with a collection of vintage film cameras, many of which have no metering system and several of which meter stopped down. The key to using a manual exposure camera (your K-3II in M mode) is to meter once to get your settings and shoot freely until either the light or subject changes. The ability to adjust exposure in real time for each shot is highly overrated. If one stops to meter for every shot, the shot will walk away before you get your dials and rings in order.
Have fun!
