Originally posted by Tonytee Hello, I tried using that link several times and I get this message: Error 404 Not Found. Another possibility entered my little pea brain and that is if I were to upload images using the SD Card instead of the USB Cable. Might be worth a try. My apologies, your questions are over my head, so I do not know. What I do know is that when I tried to use the PC's Monitor Controls, I get the PADLOCK Image and cannot do anything. Many thanks for your efforts. Very much appreciated.
Tony
@MarkJenkins - many thank's for fixing the link.
@Tonytee
Thanks for being honest. You seem to be a real novice in this area. Let me say if you want to understand this topic fully it is one of the hardest stuff in digital photography. Whole books are written about it. Depending on your background it may even be harder. But don't be afraid ... you don't need to understand every detail.
But some basics are important. So have a first look at what wikipedia says about Color Management (
https://en.m.wikipedia.org/wiki/Color_management).
Unfortunately I only own one book that offers a whole chapter on Color Management including
Monitor Calibration and Profiling (Chapter 3). The book's main topic is Fine Art Printing for Photographers (
https://www.amazon.com/Fine-Art-Printing-Photographers-Exhibition/dp/1937538...+photographers). You'll find a lot of good explained stuff about the whole post processing process up to the print.
If you're interested in the proverbial view beyond the horizon read this book. It will offer you a lot of new insights about different aspects. It's also available as an eBook. Unfortunately in english language only the old 3rd edition seems to be availlable. I own the german 4th edition and a new 5th edition is announced for June 11th 2018.
If you’d like to hear my advice: color calibrate your monitor. Don‘t start serious work on images without color calibrating your monitors!
Without color management on your computer you may correct the monitor weaknesses within all your images. They will look ok or good on your monitor. But as soon as you exchange your monitor you may see a disaster and have to re-edit thousands of images. Spend some time in knowledge and standardization/normalization using device dependent icc profiles!
By the way - does the image that I linked to looks good on your monitor? Do you want to bite into the strawberry because it looks that delicious? What's about the different skin tones. Does they look realistic? Can you distinguish the grayscale fields? - If not, your monitor may need some help.
Good luck!
P.s. It doesn't help (you), if other people see your image as a proper and perfect image on their maybe well color calibrated computer/monitor.
