Originally posted by prof Hi,
since a few weeks my Pentax K1000's build-in lightmeter doesn't work.
I changed the batteries, but still the needle doesn't move an inch.
Have you any suggestions on what might be the problem or how I can fix it (myself or through help)?
Welcome to the forum! The K1000 is a classic.
a) Are you aware that with the K1000, with your lens cap off, the battery will drain? To turn off the light meter, you must put the lens cap on the lens.
b) Are you certain the battery has sufficient voltage? I use a volt or multimeter. It is not uncommon to get a new button cell battery, only to find it isnʻt ʻfreshʻ. 1.5v cells, when new usually measure between 1.53-1.62 volts. If it measures 1.49 or less, it may not be enough to run a 40+ year old light meter.
c) The built-in battery check for the K1000: Turn the ASA to 100 and the shutter speed to B. The light meter needle should be pointing steadily upward.
d) Iʻm fairly certain that the battery is not required for correct shutter speeds which are governed mechanically. Therefore, you can use any number of light meter apps with your cell phone. Set the film ISO/ASA, and the app will give you various aperture and shutter speed combos.
Hereʻs a link to the ownerʻs manual if you donʻt already have one.
http://www.cameramanuals.org/pentax_pdf/pentax_k1000.pdf
