Originally posted by boriscleto you can use PK on EOS but not the other way around...
I did not know this... I added thi example as I have a nice Zuiko collection, and while there is an OM to PK adapter, it adds an elements that just takes away from the original glass.
---------- Post added 06-08-18 at 07:35 PM ----------
Originally posted by Ontarian50 On the down side, removing the M42 adapter from the body is fiddly.
I use the cheap $7 ones, and the trick with those is to take off the screw a lever on the adapter, screw the adapter in the lens itself and then just treat the lens like a PK one (but it does not "click" into place. Have had no issue with those getting stuck at all.
Originally posted by Ontarian50 The main question is .... why? What Kiev lens could you possibly mount on a Pentax K-50 that wouldn't be massively out-performed by a stock Pentax lens.
Well, I am not seeking a particular one off the web, but I have someone with a nice collection (not selling) and I wonder if I could borrow it to do some astro.
