Originally posted by dnabs Yesterday morning I got error “card electronically locked” for slot 2 and when I removed the card it was extremely hot and the card had partially melted in the slot! I'm able to use slot 1, but there's still a bit of the label from the card stuck in slot 2 so I'm scared to mess with it. Since this happened it's also only letting me preview a few photos in camera before error message “this image cannot be displayed” happens. I've never had any problem with this camera before. I messaged support from the Pentax website right after it happened and still haven't heard from them so I thought I'd check here. Attaching photos of the slot and the damaged card (not really worried about losing the card, just want to show for the sake of clarity). The camera might still be under warranty, but should I try to remove the bit of label from the slot first and see if it was just something wrong with that card? Or is it definitely more like a short that needs to be fixed professionally or maybe even replaced under warranty?
Ouch! I would also point the blame at the card. My recommendation going forward would be to use a reputable card brand (Sandisk is a sure bet, as long as you order from an authorized dealer). Also, with a card such as yours, you'd be getting sub-optimal write speeds anyway, so it's lose-lose. More info on that can be found here:
Comprehensive SD Card Guide for Photographers - Articles and Tips | PentaxForums.com
If it turns out that a repair is needed to get the slot working again, definitely provide as much detail as possible, and send the card in together with the camera. This would probably not be covered under warranty, unless the camera is found to be the source of the malfunction.
Info on initiating a repair can be found here:
US Pentax Warranty Repair Information - PentaxForums.com Adam
PentaxForums.com Webmaster (
Site Usage Guide |
Site Help |
My Photography)
PentaxForums.com server and development costs are user-supported. You can help cover these costs by
donating or purchasing one of our
Pentax eBooks. Or, buy your photo gear from our affiliates,
Adorama,
B&H Photo,
KEH, or
Topaz Labs, and get
FREE Marketplace access - click here to see how! Trusted Pentax retailers:
