Originally posted by pboyle The lens is a Sigma 100-300mm. Will this work with my K100D.
It will work on your K100D, I have one and seldom use it having found others that I prefer. It cost me about $25 I think.
If you are set on a zoom lens to 300mm the Pentax DA L 55-300mm can be found and is a better bet (assuming it is not damaged or has fungus) but lacks the quickshift ability that the DA (not L) has. You should be able to find a DA L for under $100.
Other budget to 300mm lenses such as the Sigma 70-300mm and the Tamron 70-300mm, both of which have a pseudo macro function can be found even cheaper. I believe I have seen the Tamron advertised brand new at $99.
