Scrolling through the posts on mflenses.com it is quite complicated. Apparently Komura made many, many versions of this lens.
Some are M39 mount.
Some are T-mount.
Some had Komura's interchangeable mount (Komuranon).
Some had different type mounts on them from the factory including M42.
The thing to do is measure the diameter of the rear thread (outside). If it is 42mm than it is either T-mount or M42. If it is 39mm then you need an M39 to EOS adapter.
Anything else you are pretty much still in the dark.
If it's 42mm you could:
- take a 50/50 chance and buy a T2 or M42 to EOS adapter and hope it fits - give up if there is the slightest resistance.
- buy one of each adapter because if you buy a lot of manual focus lenses sooner or later you use both.
- take it to a good hardware store and see if they can measure the thread pitch - 0.75mm for T, 1mm for M42.
One thing that seems constant is the quality of the optics appears to quite good.
