This thread shows the forum at its best. Helpful, courteous, practical and well-informed. I'll just add a couple of points to what's been said.
One point to emphasise is that the 18-135 can do wildlife quite well, if you get close enough. Here are some examples with the DA 18-135:
Conversely, longer telephoto lenses can be great for landscapes. Some examples here:
Post your Telephoto Landscapes! - PentaxForums.com
There's a lot of scope for creativity in photography by defying conventions about focal lengths, apertures and shutter speeds. Portraits with wide angle lenses and high depth of field, landscapes with short DOF, landscapes with a narrow field of view, panning to follow a moving subject with a slow shutter speed, wildlife with wide angles - sometimes they work and often they don't, but it's creative and fun to try.
But I agree with the suggestions that one of the 55-300 lenses would be an ideal option to pair with the 18-135, for a greater range of focal lengths. I wouldn't leap to getting a more specialist telephoto lens (like the big heavy zooms such as 50-500 or 150-450, or even a 300mm prime and teleconverter) until you have tried a versatile and lightweight xx-300mm zoom first - it might be all you need at that end.
Originally posted by Aslyfox all of which share the same optics if I am not mistakencan anyone confirm that ?
Just a slight correction Allen. The three screw-driven versions of the 55-300 have the same optical formula: 12 elements in 8 groups, with the same maximum apertures and the same MFD (1.4 metres). The only optical difference is that the WR version has the newer HD coatings (a feature that is well worthwhile IMO).These are the three screw-driven models (from most basic to most featured):
SMC Pentax-DA L 55-300mm F4-5.8 ED Reviews - DA L Zoom Lenses - Pentax Lens Reviews & Lens Database SMC Pentax-DA 55-300mm F4-5.8 ED Reviews - DA Zoom Lenses - Pentax Lens Reviews & Lens Database HD Pentax-DA 55-300mm F4-5.8 ED WR Reviews - DA Zoom Lenses - Pentax Lens Reviews & Lens Database
The PLM model uses a different optical formula. It has 14 elements in 11 groups, slightly narrower maximum apertures across most of the range and a shorter MFD (0.95m).
HD Pentax-DA 55-300mm F4.5-6.3 ED PLM WR RE Reviews - DA Zoom Lenses - Pentax Lens Reviews & Lens Database
As has been pointed out the PLM has very fast and quiet autofocus, something that can't be said for the older models. I've got both the DA-L and the PLM and there's not much between them in sharpness, especially when stopped down (the PLM is perhaps a little sharper at wide apertures). But the PLM renders better and has better bokeh, and is more pleasant to use. The screw-drive versions are great value, but for me the PLM is worth the extra cost.
