Originally posted by catwalk Hi all,
Welcome to the forums!
Remember that landscape photography is much more than wide angle lenses - at times you will get better landscapes from a tele lens.
Quote: already own:
Pentax DA 35mm f/2.4 AL
Already a good lens for landscapes. You can get far with stitching several shots if you need wider.
Quote: wide angles:
Pentax 15mm f/4 ED AL Limited HD DA. Looks like IQ and focal length are fantastic for landscapes. Should this be my highest priority?
Definitely a wonderful lens. If I could have only one wide angle it would be this. It
is very wide, though, and as such a specialty lens. A DA 21 would be more versatile and is quite useful for more general use.
Quote: Sigma 10-20mm f3.5 EX DC HSM. On the cheap side for a wide angle zoom, is it worth it?
This is a decent lens that definitely can give you great results. The main drawback as I see it is its size. It's not a lens that will be in your bag "just in case" as a DA 15 will be.
Quote: Pentax 12-24mm f/4 ED AL IF SMC P-DA. Way over budget for me. Am I better off saving up for it than going for the sigma?
Have never used this, but from what I see it is a better performer than the Sigma - and in some ways better than the DA 15 as well. Not a small lens, though.
Quote: telephoto:
Tamron AF 70-300mm f/4.0-5.6 Di LD Macro. $130 sounds too good to be true and AF is reported to be slow.
Pentax 50-200mm f/4-5.6 ED SMC DA WR. The WR is nice but looks like a kit lens otherwise.
I would skip these. They are not horrible, but...
Quote: Pentax 55-300 f/4.5-6.3 ED PLM WR RE HD DA. Any better than the 50-200?
...this is quite a lot better in every way. I have the old 55-300 (non-PLM) and am quite happy with the image quality for such a small and light tele lens. The PLM looks to be at least as good - and it focuses quickly and silently. The old one has a rather slow and noisy AF.
Quote: Not really sure if I need these since my main interest is landscapes. I can always fill this focal length in with primes instead.
standard zooms:
Pentax 18-135mm f/3.5-5.6 ED AL IF DC SMC DA. Looks like a good all-in-one for snapping shots along the trail.
Pentax 18-55mm f/3.5-5.6 AL SMC DA WR. I probably don't need this because affordable primes will likely give me better IQ here.
The 18-135 is better than the 18-55 (and has silent focus), but I think the
DA 16-85 is better still. The extra width may buy you some time before shelling out for that DA 15, too
And even though I prefer to use primes whenever I can I find it very useful to have a good standard zoom at times.
Good hunting
Edit: Adding a few sample shots - hope you don't mind.
DA 55-300 (the old one)
DA 18-55
DA 15
Sigma 10-20/4-5.6
DA 18-135
