07-09-2018, 03:41 PM   #1
funkythiru's Avatar
How to prevent this pattern when taking dimly lit photos?
IMGP2257 | Ganesh Selvan | Flickr.
Is this a fluorescent lighting issue or shutter speed issue? TIA
07-09-2018, 03:46 PM   #2
Otis Memorial Pentaxian
LED street lamps? I assume you are referring to the horizontal banding visible on the pavement.
07-09-2018, 03:51 PM   #3
First thing popped into my mind was jpeg banding. Maybe Moire ??
07-09-2018, 03:52 PM   #4
QuoteOriginally posted by funkythiru Quote
Shoot under 1/50s and you should be good
07-09-2018, 04:20 PM   #5
photoptimist's Avatar
Don't use an electronic shutter unless the shutter speed is a multiple of the line voltage frequency in your area (usually either 60 Hz or 50 Hz)
Using the mechanical shutter will avoid the banding although there may be slight exposure and color-shift issues with faster shutter speeds.
07-09-2018, 04:29 PM   #6
funkythiru's Avatar
ES strikes again. Got it, thanks guys.
07-09-2018, 04:58 PM - 1 Like   #7
This photo is in a series of three, one of which is free from banding. The image free from banding is taken at ISO 100 and with a shutter speed of 0.3 of a second. It is both a fluorescent and a shutter speed issue. As Adam said , keep your shutter speed lower than 1/50 as you did in the third image and you will be good.
07-09-2018, 05:37 PM   #8
Kerebron's Avatar
And remember to set correct AC frequency (50 or 60 Hz) in camera options.
07-10-2018, 03:33 PM   #9
Not using an electronic shutter is necessary, but not sufficient, to avoid it. I never use an electronic shutter and have seen the banding.
07-10-2018, 03:54 PM   #10
QuoteOriginally posted by leekil Quote
That is quite possible. Some high-efficiency fluorescent lights and LED light use much higher frequencies that the powerline frequency. With a very short shutter speed, the scan of the mechanical shutter slit occurs over more than one cycle.
camera, issue, pentax help, photography, troubleshooting
Architecture Dimly Lit Kirks Kerrowdown Post Your Photos! 26 07-27-2018 05:36 AM
Abstract Another Dimly Lit Kirk Kerrowdown Post Your Photos! 18 06-18-2018 12:53 PM
Nature Only you can prevent... gifthorse Post Your Photos! 2 08-16-2016 11:04 AM
Auto focus in dimly lit locations. Mymon88 Pentax K-r 2 10-08-2012 11:27 AM
Should Congress Prevent The Bush Tax Increases From Taking Effect? mikemike General Talk 43 10-12-2010 11:28 AM
All times are GMT -7. The time now is 07:25 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
