07-11-2018, 03:40 PM   #1
150-450 DFA will not auto-focus.
My K3 has been recently returned after repair to the computer and now my 150-450 will not auto-focus. It maintains MF on the LCD screen regardless of the toggle switch setting, all settings on the lens are set to AF as well. My other lenses 70-200 DFA and the 18-135mm kit lens work fine. The firmware upgrade is 1.30. All other features of the lens work but when the 150-450 is attached the camera will not auto-focus or retain the menu feature, it just flashes up and then is gone. Is this a lens problem or a camera problem?
07-11-2018, 03:53 PM   #2
Hi Craig, my guess would be that the lens probably doesn't connect well to the body.
Did you try cleaning the contacts on the mount both on your camera and your lens?
This is quite a heavy lens, if there is any play in the mount, the weight might amplify it and cause a bad connection. Any dirt could make matters worse.
Also, I guess you know it, but you should hold the camera+lens combo by the heaviest component (in your case this is obviously the lens) to avoid putting unnecessary strain on the mount.
07-11-2018, 03:57 PM   #3
RobA_Oz's Avatar
Hi Craig, and welcome to Pentax Forums. I see you’ve taken your time for a first post!
Anyway, I can’t be too precise about your issue with the D FA 150-450, as I don’t have one, but from your description it sounds like a lens problem if your other lenses work as normal. What do you mean by “menu feature”?
07-11-2018, 05:08 PM   #4
QuoteOriginally posted by RobA_Oz Quote
Thank you pjsaure, all connections are tight and have been cleaned multiple times. You are correct, it is very heavy and so it is carried properly and carefully.
Rob_Oz, thank you, I agree, the lens is the more likely culprit. By menu feature I mean the LCD display that controls the camera features which normally allows me to scroll through it but now it only flashes on screen and then disappears.
07-11-2018, 05:55 PM   #5
MarkJerling's Avatar
Anyone near you Craig, with a Pentax camera, that can test the lens on their camera?
Also, you could install the latest firmware version for the camera and see if that helps. (1.40)
07-11-2018, 06:58 PM   #6
It takes 2 surfaces to make an electrical contact. Check the contacts inside the lens mount also and give them a good clean.
07-12-2018, 11:13 AM   #7
Thank you MarkJerling and Jbinpg. The latest firmware for the K3 is 1.30. 1.40 is for the K1 and all contacts are clean. I have made a fb request for a different camera body to test it on, no luck so far.
07-12-2018, 11:51 AM   #8
Seeker of Knowledge
aslyfox's Avatar
Although I don't think it is the answer to the OP's problem
the K 3 has a new update
1.40 is the most recent for the K 3
K-3:
Changes to V1.40
Optimized performance when attaching new lens HD PENTAX-D FA*50mmF1.4 SDM AW.
Improved stability for general performance.
*Contents of [Version 1.30] and earlier version will be also updated.
Latest K-3 Firmware Update : Software Downloads | RICOH IMAGING
K3,KP,K1 firmware update - Page 3 - PentaxForums.com
I just uploaded it.
03-17-2019, 01:08 PM - 1 Like   #9
DFA 150-450 autofocus problem
bought mine in June, 2017. never dropped or damaged; treated like a baby. today it just stopped autofocusing. not sure why, but it's not the camera, nor the user. I thought that the DC autofocus motor of this lens was a point in its favor, unlike the SDM motors of old. Fortunately, its still covered under a 3 year extended warranty. Has anyone else experienced this problem? What is the cause? Is there any remedy other than sending it away to the lens hospital?
03-17-2019, 02:39 PM   #10
Mikesul's Avatar
Sorry to hear that you are having trouble. It is a pretty reliable lens but anything can develop problems. You are lucky to have the extended warranty. First be sure that the AF/MF switch is working right and set right. Check the lens contacts. If all you see is good send it in for repair.
03-17-2019, 04:32 PM   #11
Thanks,
I’ve checked both of the above, and gently cleaned the contacts; still no life😔
03-18-2019, 03:54 PM   #12
QuoteOriginally posted by Craig Carson Quote
Did you find a solution Craig?
03-18-2019, 03:54 PM   #13
QuoteOriginally posted by Tbone51 Quote
Thanks,
Sending it for repair?
03-18-2019, 06:14 PM   #14
QuoteOriginally posted by MarkJerling Quote
I can’t speak for Craig, but I’m sending mine in for repair. Will provide followup...
04-04-2022, 04:12 PM   #15
Hello. The focusing motor in my Pentax 150-450 has died. Not on warranty. Do any of you know of a source for a replacement motor I can install (I’d buy the motor). Or, I’m also willing to send it in for repair if need be. Any recommendations on that? I’d prefer to buy a motor…even a good used one. Thanks
auto-focus, camera, dfa, lens, pentax help, photography, troubleshooting
DFA 150-450 vs Sigma 150-500 gerax Pentax SLR Lens Discussion 26 05-21-2018 09:24 PM
Owners of Pentax 55-300 and 150-450 - Are you still glad you bought the 150-450? Joyce Keay Pentax K-70 & KF 16 02-17-2018 05:55 PM
DFA 150-450 Focus buttons RobG Pentax SLR Lens Discussion 8 03-22-2017 04:47 AM
Simple lens shootout Pentax HD DFA 150-450 vs Canon 100-400 II vs Sigma 150-600 C beholder3 Pentax SLR Lens Discussion 46 07-25-2016 12:33 AM
Nikon D7200+ Sigma 150-600 S vs Pentax DFA 150-450 Shanti Canon, Nikon, Sony, and Other Camera Brands 43 12-13-2015 09:02 AM
All times are GMT -7. The time now is 08:24 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
