Originally posted by GUB Pentax lens registration distance is 45.46.
Flange focal distance - Wikipedia
But you also need to work out how far the elements need to be from the sensor. Theoretically of course 90mm here but telephoto design makes that not hold true. So you need to try and work out infinity focus distance. Point the lens at the sun (infinity) and measure the distance to a piece of paper that is now on fire because you have it focused!!. Subtract the 45.46mm (From the flange at the bayonet) and you have some idea of the construction. Better to be a little short rather than long - it just means it will focus beyond infinity.
Thanks! I will try that trick with sun and paper. It's been a while since the last time I used a lens to set paper on fire... Good old days...
---------- Post added 07-26-18 at 01:10 PM ----------
Originally posted by Medex Colorpan 90 mm is not a big lens. Use smaller diameter helicoids with m42 thread and m42 to PK adapter (chinese silver color is OK) as well as adapter to hold the lens inside helicoid. The longer adapter, e.g. 35-85 enables you to have more extension (50 mm) or smaller 25-55 - 30 mm. In case of longer helicoid you will be able to make close focus pictures
Thanks for the advice. I got an adapter to hold the lens inside the helicoid. It has a M42 thread, so I need m42 to m42 focusing helicoid, just wasn't sure what size. I`ll try 35 - 85mm. Would love to try close focus photography with color plan...
