Originally posted by harryflook Hi there,
New to this forum, so hello.
I just recently picked up a beautiful ESII in great condition, everything seems to work mechanically and the glass is all clean.
However I put some batteries and can't get the light meter to function properly. The pin moves to the middle when I hit the battery check, and when in automatic mode it goes from it's original position above above 1000th to below 8 seconds no matter what the light, when the shutter is half pressed. As far as I can tell, the shutter fires the same speed in automatic no matter what the lighting conditions and aperture settings, but in manual it does change as expected from 60th to 1000th.
Any suggestions? Is it possible to fix the meter?
Thank you!
What batteries are you using? The manual indicates using 1.5V silver oxide batteries (Eveready S76E or Mallory MS-76H).
Regards
Chris
