07-27-2018, 04:10 AM   #1
Old Timer brains needed K10 Firmware and the "Russian Workaround/Hack"
Hi
Had a K10 for years. It died after lots of use. Loved it. Needed a new SLR v.quickly as away on a trip shortly. Decided to get a second hand K10 as stop-gap - It arrived today. Trying to set it up before I head off. Running out of time.
I'm ploughing though various threads, forums etc, searching my old bookmarks etc but not getting anywhere fast enough.
Can anyone help/confirm any of the the following or in an act of human kindness help out please?
A
Camera I just got is firmware version1. There seems no option to use the OK button and front dial as ISO changer when in Manual mode. I was expecting this function and it not being there is a serious bummer. I think this was a shortcoming which was tweaked/overcome with ver 1.2 upgrade which was the firmware on the K10 I bought years ago. Correct? I need this functionality.
B
How/where can I find a location to update the v1 this replacment camera has to the v1.2 I used?
C
Back/front focusing lens issues could be adjusted using a firmware hack. I think it was widely known as the "Russian Hack"??? This hack went into hidden menues in v1.2 and allowed adjustments. I used it at the time but just cannot find any reference to it on my bookmarks/downloads etc.
I remember being very nervous about doing the hack but there were clear instructions and all worked out well and pin sharp lens focus as a result.
Can anyone point me towards the Russian Hack and instructions please? Perhaps there were other hacks? - anything that works safely will be enough but I need to have some confidence that things will go OK - I seem to be reading bits about some hacks going pear shaped but I could be speed reading too quickly.
D
From searches I see there are references to version 1.3 etc etc. I get the impression such firmware updates shut down access to some of the tweaking I want access to as per the Russian? Once installed, reversion from v1.3 to earlier seems difficult? True or not, I'd really just be happy to get to v1.2 and the Russian hack so long as I can get the ISO functionality back again and the opportunity to tweak front/back focusing.
I will keep looking but if there's someone out there who can help in a hurry and who knows what I'm after and is confident that I'll then be using the correct sources etc, I would be extrememly grateful. And that's putting it mildly.
Thank you very much.
eggmammal.
07-27-2018, 04:36 AM - 1 Like   #2
BigMackCam's Avatar
Hi and welcome
The firmware updates for versions 1.01 through 1.30 are here:
Pentax K10D - Downloads - RICOH IMAGING EUROPE S.A.S
Latest v1.31 firmware is here:
http://www.ricoh-imaging.co.jp/english/support/digital/k10d_s.html
To get the DEBUG menus (which will allow you to adjust for front or back-focusing), create a file called MODSET.TXT with one line in it - [OPEN_DEBUG_MENU] - and save or copy the file to the root of your SD card, place it in the camera, then - leaving the SD door *open* - switch the camera on. You can then enable or disable DEBUG mode as required.
Hope this helps. If you have any more questions, let us know
07-27-2018, 05:21 AM   #3
Not a Number's Avatar
You might try PK_Tether which will toggle you in and out of debug mode interactively. It might not work with some versions of the firmware though.
PK_Tether – Tethering software for Pentax DSLR |
I thought there was a way to save a binary image of the current firmware from the debug mode? If so, save the v1.21 (there is no official 1.21 so it must be a hack) and upgrade the "new" K10D with it. Check in the firmware hacking threads and websites.
Note: the max card size on the K10D is 32 GB.
07-27-2018, 06:21 AM   #4
Thank you
---------- Post added 07-27-18 at 06:32 AM ----------
Hi and welcome
Latest K10D Firmware Update : Software Downloads | RICOH IMAGING
Thanks Mike
Seems that v1.11 will be sufficient my needs. Appreciate help - I'll give it a bash tomorrow. I'll come back any problems.
PS The ME Super. What a cracker. My first SLR.
Cheers. eggmammal
07-27-2018, 12:58 PM   #5
I'm not sure if you can even get just the 1.1 version of the firmware, but I would recommend the newest (1.31) version as it has a fix for issues writing to certain SD cards. And possibly other fixes they don't mention.
07-27-2018, 01:04 PM   #6
BigMackCam's Avatar
QuoteOriginally posted by leekil Quote
The first link I provided in my earlier reply is to Ricoh's own K10D firmware update archive, which includes v1.11 and all others prior to the latest. The second link is to the v1.31 firmware...
07-27-2018, 08:57 PM   #7
i_trax's Avatar
I stopped on 1.20 so I can use screw-drive AF on broken SDM lenses
08-22-2018, 11:08 PM - 2 Likes   #8
I'm sorry for the delay (been away) but I want to thank everyone who helped and provided suggestions. It all worked out well and I was able to update firmware. Appreciated.
access, brains needed k10, camera, card, debug, debug mode, file, firmware, firmware 1.2, hack, hacks, k10, k10 firmware, k10d, mode, pentax help, photography, ricoh, russian, russian hack, timer brains, troubleshooting
Macro+Infinity Focusing Russian 50mm f1.2 Lens for $50 DIY Hack..For A6000 Sliver-Surfer Non-Pentax Cameras: Canon, Nikon, etc. 2 10-05-2017 08:22 AM
Help! Out of date and uncertain of IQ standards and need to pick your brains Roland Stockham Pentax SLR Lens Discussion 17 01-03-2017 12:21 PM
People Mmmmm Brains ChrisTrevino Post Your Photos! 2 02-12-2013 06:48 PM
Eyes, Brains, Sensors, and Research mithrandir General Talk 8 02-05-2010 01:11 PM
(old timer) How to read this old timer light meter? fearview Pentax Camera and Field Accessories 1 11-03-2009 05:26 AM
All times are GMT -7. The time now is 11:05 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
