Originally posted by raf My viewing screen, that is the large screen to view the image and the menus is rather greasy from my perspiration etc. I have attempted to clean it using various methods, done of which has worked.
I am certain that this is not an uncommon problem and many of you would have found a solution. Advise please
My suggestion is to get an eye glass cleaning fluid or some 91 percent Alcohol. If you get eye glass cleaning fluid, DO NOT SPRAY IT ON THE SCREEN. Spray it on a clean soft cloth and wipe the screen with the soft cloth. Same goes for the Alcohol. put a little bit on a clean cloth and wipe the screen. Turn the cloth to a dry side and wipe again.
I would also suggest getting a screen protector. I use the screen protector from AcMaxx. They are a tempered glass and I am happy with them. You can find them on ebay.
