07-27-2018, 01:22 PM   #1
K-5 IIs wont flash sync faster than 1/40s in M mode
I just bought a second hand pentax K-5 IIs. Im having a problem using the built in flash. Im using a K lens, Manual mode.
The flash works fine at shutter speeds 1/40 or slower, but at faster speeds the resulting pictures are partially or fully out of
sync (black). Flash mode is set to flash ON. simple manual flash. Is the camera defective? What am I doing wrong? My istDS
doesn't behave like this under same settings and condtions, it syncs all the way to 1/180s.
07-27-2018, 01:40 PM   #2
QuoteOriginally posted by jco Quote
Many old flashes have a sync speed of 1/60s AFAIK. Also, the DS supports TTL, whereas the K-5 does not, which is why the exposure could be more consistent there. Just a guess!
07-27-2018, 01:53 PM   #3
jco
Im not talking about using an old flash with the k-5 IIs, im talking about using its own BUILT IN FLASH.
07-27-2018, 01:55 PM   #4
Ah, missed that. Could still be related to the TTL, since on the K-5 your exposure is 100% manual. Maybe try a wider aperture?
07-27-2018, 01:56 PM   #5
jco
And secondly, I should make this clear, this is not an exposure problem, its a SYNC problem.
---------- Post added 07-27-2018 at 05:03 PM ----------
when you use a "K" lens, there is no TTL exposure or sync, the flash is supposed to fire full power manual at the rated sync speed of 1/180s regardless of lens aperture setting.
07-27-2018, 02:06 PM   #6
I *believe* that on the DS it will use the TTL sensor in the camera to measure the light in real time. This was removed on future bodies in favor of the P-TTL preflash approach.
I'm afraid that where my expertise with shooting with flash + manual lenses ends. Perhaps someone else can chime in so we can determine if it's a settings issue or an actual problem with the camera.
Are the resulting images consistent?
07-27-2018, 02:11 PM   #7
jco
According to the manuals for both cameras, the K-5 IIs and the istDS should both operate the same way with flash using K lenses and manual flash.
---------- Post added 07-27-2018 at 05:18 PM ----------
This is incorrect, with K lenses, both the K-5 IIs and the istDS do NOT measure or meter the light output from the flash, instead, the flash just fires FULL OUTPUT MANUAL and the correct exposure
can only be obtained be setting the aperture value on the lens correctly. The key is that ANY shutter speed 1/180s or slower can be used. Im having problem from 1/45 to 1/180
07-27-2018, 02:51 PM   #8
UncleVanya's Avatar
And this is ONLY in M mode? I don't have the K-5 does it have an X mode? I have often gotten frustrated with flash on my K-3 and just turned there to get the max shutter speed and manually adjusted everything else.
This isn't your problem but your settings for Tv steps can matter. Don't set it to 1/3 set it to 1/2 to get form 1/160 to 1/180. But again that's not your problem.
07-27-2018, 02:54 PM   #9
enoeske's Avatar
Can you post one of the black or partially black images with full exif data intact? Maybe a dropbox link?
07-27-2018, 02:57 PM   #10
jco
The K-5 IIs does have a X mode, where the speed is a constant 1/180s. I tried that too and the flash would not sync with a K lens, blank pictures on X mode.
07-27-2018, 03:04 PM   #11
UncleVanya's Avatar
OK - that's weird. Is this lens maybe painted or anodized? I'm clutching at straws here.
07-27-2018, 03:16 PM   #12
jco
same lens syncs fine on an istDS
---------- Post added 07-27-2018 at 06:19 PM ----------
SMCK 28mm f3.5
---------- Post added 07-27-2018 at 06:21 PM ----------
QuoteOriginally posted by enoeske Quote
already boxed it up for return to seller. didn't save files
---------- Post added 07-27-2018 at 06:25 PM ----------
Does anyone here have extensive experience shooting with the on camera flash on the K-5iis with K lenses in M or X modes?
07-27-2018, 03:54 PM   #13
mattt's Avatar
I shot plenty with K-5IIs + M / K series lenses.
As the pop up flash fired at full strength (it does not support TTL, just P-TTL) I only used flash photography with AF540 FGZ or AF360 FGZ in manual or A mode.
If you want to use the onboard flash with proper exposure you need at least A series lenses which communicate aperture to the body. With no aperture communication. You are expecting sync performance from an incompatible system.
---------- Post added 07-27-18 at 05:10 PM ----------
Just for kicks - if you still had the camera - I would make sure the flash settings in body were not set for second curtain. I would also try to rule out a shutter issue by doing tests in Hi speed continuous shooting through a full range of shutter speeds.
If you have boxed it up and shipped it back it’s a moot point.
07-27-2018, 04:55 PM   #14
jco
QuoteOriginally posted by mattt Quote
are you saying you never used just the built in flash with k lenses at 1/180s?
07-27-2018, 05:08 PM   #15
For what it's worth, I just tested my K-50 with the M 50mm. The exposures were bright and consistent in M mode with the flash on, in both trailing curtain and regular sync, at 1/180s. F11 was needed for proper exposure for a subject about 3m away.
No reason why the K-5 wouldn't behave the same way, so I'm thinking sending it back may be the right call.
aperture, body, camera, exposure, flash, flash sync, im, istds, k-5, lens, lenses, light, measure, mode, output, pentax help, photography, pm, post, speeds, sync, syncs, troubleshooting, ttl
Keep lowest ISO and shutter speed faster than 1/400s in Av mode... bertwert Pentax DSLR Discussion 15 01-05-2017 04:31 PM
Isn't K-1 crop mode a good place to allow flash with shutter speed faster than 1/200? jake14mw Pentax K-1 & K-1 II 7 06-10-2016 01:00 PM
Bower flash wont sync in slave mode. haassaasin Flashes, Lighting, and Studio 3 08-23-2015 09:16 AM
Trigger flash faster than 1/160?? ChuckB28 Flashes, Lighting, and Studio 26 08-27-2013 12:02 PM
Faster Flash Sync geauxpez Canon, Nikon, Sony, and Other Camera Brands 16 06-12-2012 09:47 PM
All times are GMT -7. The time now is 03:59 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
