Originally posted by mroeder75 I practiced on two guinea pigs, mom and dad. And, either they, or I did fairly good. Not great. But, fairly good. A bit overexposed but considering I had it on camera setting "M" it was good for me.
---------- Post added 08-02-18 at 12:29 AM ----------
Is the lens serviceable?
That looks pretty good to me! If anything, a suggestion for a new test: the Pentax-May 50mm f/1.7 is a bit soft at maximum aperture, so to be sure, you will want to shoot again in live view and using amplified view (the ok button after you set the scene), use focus peaking to manually focus, with the lens stopped down to 2.8, for example, or ever better, 4. That way you get the right depth of field and just make sure the eyes are in perfect focus.
You should get really sharp images from this test. Good luck!
