Originally posted by Schraubstock Interesting discussion.
I have no experience with Apple computers or Apple monitors and it could very well be that your monitor is not optimal for true colour work, rather it is optimised for consumers who love over-saturated and contrasty pictures. There is market for these as in general the average consumer is demanding those over-saturated colours they see every day in advertising and on their smartphones, and this grey front panel or whatever it is facilitates this. So I cant comment.
In my work it is important to be able to produce colour correct images. To achieve this I work with an EIZO Coloredge CG2420, a monitor with an inbuilt calibrator, which when once initially correctly calibrated, will automatically re-calibrate the monitor automatically every 8 weeks. Usually during an off period.
The last image you supplied is under exposed and has a distinct yellow cast. I see this very often with pictures posted here, particularly those images which were taken during sun rise and sundown before the so-called blue hour.
There is a huge difference between a true warm sun set rendering and the look that is achieved by adding a bit of extra warmth by adding a bit more yellow. And often people do not know when to stop. It makes the picture look like as if a clear yellow blanket was thrown over the picture. When you do this everything in the picture is overpowered with this yellow cast, even parts of the image which should not be affected by the natural warmth of the ambient light. When you then add to this underexposure you finish up with a bad picture.
I have corrected your picture (as much as an 18bit JPG would allow) by importing it into a program called Oloneo PhotEngine. This has a colour picker (pipette) allowing you to hone in on a very small neutral grey part in the image. In most picture you will find one of those. In your picture this was easy. The moment you click on this grey spot it changes everything. And there is, in almost all cases if not all, no arguing that the photo is now correct. Note how the grass in the foreground has changed because a yellow cast always makes green more green. This could be a problem with some folk if they like this fat green in which case they have to go into the green channel and tickle the green a little. But don't forget some people cannot see certain colour correctly and they will argue with you that broccoli isn't green.
As to the grey card you must make sure that the card is actually part of the picture you are taking. Portrait photographers in fact will ask the model to hold the card for the pilot photo. This photo will then be discarded once the correction details are noted or stored as a preset for all others which were taken under these conditions.
Cheers
P.S.
1) You have dust on the sensor
2) The sky is not optimal which is always a problem when working on 8bit images. In RAW this will not be a problem.
Hi and thank you again!,
Yes, I am a dirty man, my lenses have no covers, many need to be taken apart and cleaned. i usually bring an old tamrac bag of dusty primes and switch like every two min for angle and depth practice. the place is dusty as hell.
This was my first lens today so it should look a bit be cleaner.
I just came home and gotta take a fast nap soon. I got the grey cloth
and I used in the corner for reference. half of the grey is lit half is shadow
so is the photo. the original photo was totally yellow as usual..
https://imgur.com/a/iTlTOEn
Here is how I see things but maybe I am wrong.
foreground grass is too cold and needs to be referenced to cold grey
background is too warm and needs to be referenced to warm grey
I stacked two layers added alpha to layer and erased the top too warm lake top with the eraser and flattened both images to one and cropped it.
used a program called darktable and gimp from software center in ubuntu 18
is what I did about right? I know it could be done better and in raw. I bought a software called luminar i didn't start to use it yet. I am kind of reluctant to move back to windows, but I will start using it when I have a decent photo to show. I can not thank you enough for your help!
ps: i am working on an old Eizo will trade it for an iMac that collects dust and takes space on my desk, on apple cinema every grass looks like astroturf , red is screaming blacks are too black. its ok for watching movies and I guess is a good 2nd reference because every phone is screaming colors nowadays.
1. attachment. spot grey taken from grey shade area
2 attachment spot grey taken from grey sunlit area
3. stacked 1 and 2 erased top of photo 1 and used photo 2 for upper part of flattened merged photo
---------- Post added 08-09-18 at 02:43 AM ----------
Originally posted by pentasonic49 There is a world of difference between a true macro lens and a zoom lens with "macro" printed on it. Don't be fooled, the zoom lenses are not suitable.
I am sure you are right about that I there is one, 50 mm with the life-size adapter I think is Minolta rokkor x. I am not sure if I need lifesize but sound about ok. I still have to wait a few days for the auction to finish.
I have several macro zooms but no macro primes. Thank you for the hint!
