Originally posted by Just1MoreDave Wow, you can nearly read the label on the equipment box.
Yay! I was pretty excited about it. Today i seen that the crane was facing to the other side and gave it a try, and i could actually guess the tools needed for some bolts up there. I'm a car mechanic so i'm used to guess it, but sure not at 100-150 meters away!
Originally posted by ChipB That filter had quite a negative impact on photo quality!! What lens were you shooting with?
It's an SMC Pentax-DA L 1:4-5.6 50-200mm ED (entry level as far as i understand) that i thought was borked or just low quality until i removed the CPL filter :P
I plan to do something with it. BTW i broke and thrown away the glass to avoid temptations, and i may end doing something like a bokeh mask. I need to figure what shapes i'd like and so on but at least i have a 52mm ring ready to go.
However, tomorrow i start recieving material for my macro assist led ring so i'm surrely getting busy with DIY crafting
---------- Post added 08-19-18 at 06:07 PM ----------
I've been playing around with Bulb mode, and i'm curious about what is the time limit, let's say on a constant DC supply? I mean, i don't feel really confortable doing more than 30 secs as it's what Pentax limited the camera by default, but idk if it has a safety limit or it will just plain damage the sensor if i do a so much long exposure? I plan to learn with this camera at low light situations, since i'm seeing its potential and i'm amazed with it.
Also another doubt, in Live View, i find that with an AF lens, the image will zoom in wherever the focus point is set. There's a way to do this on manual lenses? It would be really useful.
