Originally posted by i_trax you need to provide more details and perhaps some pictures, what is the auto coupler?
Well, take a photo of the AF not working. With an AF lens, you push the trigger in half way. The lens runs to the end stop then reverses to the other end stop and quits. This happens every time you push to focus. If you manually focus the lens, the pentagram will appear in the viewfinder when focus is correct. I'm an electronics tech and am curious as to how the AF functions within the camera.
The second part of the lens issue was mechanical. Someone had reefed the lens off at one point and jammed the auto coupler (the AF drive coupler) into the ring so it wasn't functioning at all. The first try resulted in the shaft not allowing the lens to be removed as it wouldn't retract in either MF or AF mode. I was able to compare the linkage to my other IST and fix it.
