Hello,
I have been using my Hoya Circular Polarizer (link below)... really amazing, and love the quality for the value.
I purchased a 77mm, so that I would be able to use the CPL on all of the my lenses, with the use of a step-up rings. However, after using said step-up rings my Hoya CPL is now stuck on the 77mm ring. Because of the way that CPLs are made, when you try and spin the CPL, it simply rotates on the housing... which I imagine is making it difficult for me to apply enough pressure to the ring to get it off. I don't have a problem with the step-up rings that link to this ring. In truth, I can (and still do) use the CPL as intended as none of my lenses are 77mm (72 is the biggest).
Was just wondering if anyone had a remedy for when they have a something stuck to a ring?? Another potential remedy might be just cutting the ring off in order to get to the CPL, but I'm hoping to go that far.
Thanks,
