Originally posted by Kmier Alex,
I found that any time I have the lens set to “A”, the camera will always drive it to f22 upon exposure (shutter speeds seem appropriate). Otherwise, with any of the AUTO F- -, M, 60, B, settings (with a lens aperature physically set), I get normal action.
Does this still point to goofed-up camera electronics in the AUTO modes?
Manual mode is the way I’ll move forward, if I can get consistent results. Maybe now I can start to look at a couple of extra lenses.
IDK. I could imagine reasons why it's the lens or the camera, but I don't have experience with this exact problem and to me, it could still be caused by either the camera or the lens. With 70% rubbing alcohol and a cotton swab, make sure both metal contacts on the lens mount of the camera and the camera mount on the lens are clean.
For sure, the immediate solution is shooting in manual mode, but other options to consider:
a) Here's the forum member map:
Worldwide Pentax User Map - PentaxForums.com Do a little digging into profiles and see if anyone within driving distance also has a 645 lens and meet up with them so you can try a different lens on your camera.
b) Buy a second lens for your 645. You can get a 645 200mm f/4 in excellent condition (with 180 warranty) for only $94
Pentax 200mm F/4 SMC A Lens For Pentax 645 System {58} at KEH Camera Store
For $168 you can get the 150mm f/3.5 which is a higher IQ telephoto
Pentax 150mm F/3.5 SMC A Lens For Pentax 645 System {58} at KEH Camera Store
$278 for a 75mm f/2.8....my second favorite lens
Pentax 75mm F/2.8 SMC A Lens For Pentax 645 System {58} at KEH Camera Store
Or go for broke for $600 on my favorite lens, the 35mm f/3.5
Pentax 35mm F/3.5 SMC A Lens For Pentax 645 System {77} at KEH Camera Store
c) KEH also does repairs on medium format cameras and lens. $265 for the camera, $255 for the lens. If you sent them both, they probably would just fix the one that they found dysfunctional. Personally, I wouldn't go with this option unless you find shooting in manual mode a deal breaker and "a" or "b" above is not an option for you.
