Originally posted by Kmier Hi, All,
New to this forum; I bought a 645 with a 45mm f2.8 to play around with film once again. I’ve shot two rolls of Ektar 100 through it with dismal results - every photo is drastically underexposed. My scenes are all in reasonably sunny settings, various subjects. I know I have the ISO set right and the exposure compensation is at ‘0’. Fresh batteries, and everything seems normal.
I don’t see a ton of threads describing this issue. What should I look for to resolve this?
I've owned a 645 since they were new in the 80's and mine has always underexposed. It works really nicely for slide film, but not what you want for negs.
I think it has a lot to do with metering pattern and that the meter is overly influenced by bright skies or highlights. I would recommend using one roll just for tests.
a) Shoot half a roll of Ektar 100 of a neutral evenly lit low contrast subject such as brick wall. Avoid anything that has bright highlights and dark shadows. Try -1EV, N, +1EV, +2EV, and +3EV. Then find a landscape scene with a bright sky, preferably high contrast with some clouds and a few deep shadows. Bracket your exposures the same.
It is possible that your light meter needs recalibration or that you accidentally had it set to some -EV value, but I doubt it. In general, I will shoot negs at +1EV or rate an Ektar 100 at 50 ISO. You can also use another camera that has consistently good exposures to compare with your 645 to see approximately how far off it is and how much compensation is required.
BTW: Are you sure the lab isn't underdeveloping (too little time, exhausted developer, too low temperature) your Ektar? Does the edge numbering look dark with a clear orange stained base? Or does it look a bit faded?
