Originally posted by agrolingua Is it connected to the body with wires, etc.? How many wires are there?
Six coloured wires one side and a 'Ribbon" on the other.
With the camera flat on it's back, there should be enough slack to undo the three screws, lift up the edge of the switch and spray in the contact cleaner.
If you need to remove the ribbon, gently lift up the ribbon side of the cover/latch with a small screwdriver, knife or similar. It is hinged on the side away from the ribbon.
There is a small piece of double sided tape under the ribbon near the connector so it will need to be peeled up prior to pulling the ribbon out of the connector.
To re-connect, push the ribbon into the connector (all the way) and push the ribbon side of the cover down (with a finger or blunt object).
If you need to remove the coloured wires, they will need to be de-soldered after documenting their positions (photos).
The ribbon is reasonably tough but if it tears (can happen if an edge is nicked) you have a scrap camera.
