08-30-2018, 02:30 PM   #16
It's not that PK_Tether is required it's just that many people find it easier to just toggle the setting in the PK_Tether menu rather than have to create the properly name modset file and add or delete it on the SD card.
Ok, just tested with PK_Tether on the K7 and unless I'm doing something wrong you still need the modset file to be able to access the debug menu.
08-30-2018, 02:50 PM   #17
Not a Number's Avatar
QuoteOriginally posted by alfa75ts Quote
See, PK_Tether isn't required. Are there any of the older models that a modset file does not work but PK_Tether does?
It could be that PK_Tether was the only option until a modset was found that worked. Or the developer made changes to PK_Tether that added support to a camera/firmware version where a modset was previously the only option.
08-30-2018, 02:55 PM   #18
Could be, but the correct modset file alone is no good unless you can enable debug mode either via PK_Tether or by pressing a button/leaving the card door open.
camera, k70 into debug, pentax help, pentax k70, photography, troubleshooting
Full Review on the Way! :) K70 Rush2112 Pentax K-70 18 11-02-2018 06:21 AM
Pentax K10- Debug mode HansrajVyas Troubleshooting and Beginner Help 3 01-09-2018 01:42 AM
Turning off DFS on K20D with debug mode dudolmen Troubleshooting and Beginner Help 2 07-14-2017 03:57 AM
K3-II fw 1.10 DEBUG MODE Gian Pentax K-3 10 05-04-2017 07:46 AM
K-1 Debug Mode lithedreamer Pentax K-1 13 11-17-2016 01:31 PM
All times are GMT -7. The time now is 08:24 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
