Originally posted by ShawnH Hi photogem, In you debug instructions for K70 you say create file name: 0007770.524 but on the line below you say you get text file with the name: 00077750.545. As you see the name are different. Is that the way it is suppose to be or is this a typo? Please advise.. Thanks for all the great work you do here.
a) On the computer desktop right click ... select "create" - select "new - text document" and give it the name: 00077770.524
You get a text file with the name: 00077750.545.txt
b) Double click to open it and paste in: [OPEN_DEBUG_MENU] (you can just copy it from here),
close, save and rename again into 00077770.524 but without ".txt"!)
Now you have a file named just: 00077770.524
Just to be sure you are aware - debug mode is crippled on newer cameras and does not allow sdm conversion to be done using those bodies. The lenses once converted do still work correctly. The debug mode does still allow some things like the adjustment of af fine focus aoutside the +/- 10 range.
