Originally posted by Penview52 pentaxian tourist..."...The only trouble I've had with mine is occasionally the shutter will not actuate when I'm in timer mode. I still haven't figured out why it's doing that, but it only happens on rare occasions."
If you have activated the timer say 12 sec. and it work for first time, activate it again for the next time around to let it work again. If you just press down the shutter, the timer will not work.
If you are in active timer mode and go back to previous mode of shooting , you must cancel out the timer mode, if not the shutter will not work.
I can't speak for the K-70, specifically, but having a K-30, K-5, and K-3 in our arsenal here, I can say this isn't how the timer works on any of those bodies. For all three of the bodies I have, once you set the mode to timer, it stays there until you change it to a different mode. In some instances, if you don't have the shooting mode set as a memory item, turning the camera off and back on works to solve it, but if you have it set to remember your drive mode, the only way to toggle between them is with the four-way selector or the info button. Once it's set to a drive mode, it stays there until you change it, or turn the camera off if you don't have the box checked to save that during power down.
One additional thing to note - on the three bodies I have, pressing the shutter in timer mode will start the timer, but pressing it a second time will cancel the timer and the shutter will not fire at all. Be sure you're not accidentally pressing the shutter twice as that may cancel the shutter altogether.
