So I'm getting to the point where I'm bumping into the need for a hood for my 50mm when taking night shots. The problem is, Unlike the later 50mm F1.4's, it has a 52mm filter ring rather than a 49mm one. I'm looking at the Nikon HS-14 as a potential option, but I'm looking for suggestions before I start buying.
