Originally posted by HarisF1 I was just thinking about this a few minutes ago. Does anyone have any tutorials for using Rawtherapee with Pixel Shift? I'd like somewhere to start with the kit.
It isn't too hard. Basically you choose a PS RAW file and go to the RAW development section (it looks like a checker board). There is a drop down menu there where you can choose the raw development tool you want. Default is usually Amaze. Switch that to pixel shift. It defaults to automatic, which works for me most of the time and you can choose which image you want for your base image. I often check the "motion mask" which will show in green any place where there was movement in your image. If there is too much movement you are probably best off not bothering with pixel shift. There are a lot of things you can do otherwise in the program -- tweaking exposure, noise reduction, but I tend to do my final processing in Lightroom, mainly because I am more familiar with that program.
Hit control-S to save the image and choose 16 bit TIFF if you want to develop it some more with a different tool or if you are happy with the settings otherwise you could just save it as a jpeg.
