09-18-2018, 09:16 AM   #16
QuoteOriginally posted by RKKS08 Quote
Modern IC controlled chargers which handle each cell individually use a sawtooth pulse, measuring delta current and voltage with each pulse. So they can decide when a cell is fully loaded without knowing what kind of cell it is. With a full cycle (discharge+charge) this also gives a picture of the health status of the cell.
Deeply discharged (unresponding) cells would first need a current-limited constant voltage till the cell starts to respond; then (after a pause) the pulse loading may get a try. My chargers cannot do this automatically, but I several times successfully revived cells which the intelligent loader marked as dead, by using an old simple (constant voltage) loader first.
I usually use Eneloops on my Kx but my K50 allows me to use a rechargeable ithium battery as well. Can anybody tell me if they will also suffer deterioration with time?
09-19-2018, 09:44 AM   #17
QuoteOriginally posted by psoo Quote
Yes they do.
Not related to your question:
Rechargeable Li batteries should only be used with chargers explicitly designed for this type.
Specially for the ones with higher capacity like for DSLRs and notebooks I would be wary about chargers not supplying the 3rd contact (some have a dummy, that's just as bad). These batteries may get too hot during charging, and if the internal temperature gets too high, the charging should be paused automatically, and continued when the temperature is far enough down.
The 3rd contact of the multi-cell batteries takes care for that, if the charger supports it.
09-19-2018, 12:47 PM   #18
Yes they do.
Hi RKK. I do use the Pentax charger for the Pentax-supplied Li battery,for my K50. Hope this keeps the battery in good shape for a long time.
09-19-2018, 02:46 PM - 1 Like   #19
I use the original Pentax charger for the K-5 and the original charger of Panasonic for the Lumix.
The reserve batteries of both are Pantonas, no problems yet. The Pantonas give less shots than the Pentax ones, and most likely will last half as long, but they cost a fraction of the original batteries from Pentax and Panasonic (the same with my IBM/Lenovo Thinkpad notebook).
But my old Lumix (also bought used) came with a cheap chinese charger (without the 3rd contact) and caused all kind of problems. I finally replaced it by the Panasonic charger (at a hefty price), but no problems anymore.
The original chargers may be produced in the same chinese factories as the cheap ones, but they will have an approved electronic design and a tight quality control
09-22-2018, 08:49 PM   #20
I recently shot about 150 photos including about 20 using flash. The Eneloops were fully charged. Is this about what I can expect from batteries in good condition?
09-22-2018, 09:49 PM   #21
I have a 16 Eneloops from 2009 I used with my KM and K200D for years. Don't use the K200D as much now because I have K5, K3, and K1. Use the Eneloop batteries for my flashes and in the extra tray for the K3 battery pack. I have my K200D and an extra 4 Eneloop batteries in a pack to go out in my boat (I go in saltwater 99% of time here on the SC coast). I have never charged them with anything but the chargers I ordered with the Eneloops. They still work fine. I had a Ray-o-vac charger ruin a bunch of ray-o-vac and other "rechargeable" batteries. I would be weary of a third party charger.
JB
09-22-2018, 10:29 PM   #22
Eneloop charger, recharges batteries individually..that is why the batteries have such a good reputation.
Energizer,Duracell ect..charge groups of 2 batteries unti they reach the voltage of the sum of two batteries or ~3v so they might finish charging with one at 1v and the other at 2v and then even worse over time until one dies..(the one that charges faster). I charge all my ni-mhs in Eneloop chargers. Don't use an aa/aaa charger unless it says it can charge 1 battery at a time.
...I mostly only buy Duracell batteries because they are good and cheap and they last forever when I charge them in my Eneloop charger.
09-22-2018, 10:55 PM   #23
Not a Number's Avatar
QuoteOriginally posted by Sliver-Surfer Quote
It depends on the model of the charger. The Sanyo branded Eneloop charger I have only charges in pairs. A good rule of thumb is if the charger has as many status lights as the number of bays for batteries, e.g. four lights four slots. Even so the charger may be charging on a timer and not monitoring the charge of the battery.
The website I linked above has a comprehensive list of all the Eneloop chargers and details which charge in pairs and so on.
09-23-2018, 06:12 AM   #24
Thanks for the last three comments on charging Eneloops. After I had trouble with my "Energizer" charger I dumped it, and now use an "Enercell" charger. It charges without causing a very high temperature to develop in the batteries. However, to play it safe I think I'll buy an Eneloop charger.
09-23-2018, 04:25 PM   #25
It appears you are correct. I am assuming they built up a good reputation from the original chargers and now they can just make lots of money off of reputation and save a tonne of cash with cheap sub par chargers. I have collected at least a half dozen of the originals from thrift stores comes in handy when I have a multi flash shoot planned.
batteries, camera, charger, ebay, eneloop, eneloop batteries, freight, harbor, longevity for eneloop, pentax help, photography, rechargeable batteries, shortcut, test, troubleshooting, volt
Eneloop batteries - Do I need a new charger ? jpzk Pentax Camera and Field Accessories 25 05-28-2017 06:39 PM
eneloop 8-Pack AA Ni-MH 2000 mAh Batteries+ Charger $28 ramseybuckeye Pentax Price Watch 6 03-28-2013 04:27 AM
For Sale - Sold: Duracell "Duraloops" rebranded Eneloop Rechargeable Batteries W (Worldwide) mulanrouge Sold Items 5 07-18-2010 09:49 PM
recharging eneloop batteries WMBP Pentax Camera and Field Accessories 38 06-11-2009 07:16 AM
Eneloop batteries and chargers julianactive Pentax Camera and Field Accessories 11 03-05-2009 11:04 PM
All times are GMT -7. The time now is 05:38 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
