09-16-2018, 06:03 PM   #1
Lens support bracket advice.
So I'm starting to ponder getting a long telephoto lens and I'm considering one of the older telescope lenses that started off as rejects from a MANPADS assembly line. (One of these to be specific) The problem is their tendency to flex.
So, what's the best sort of support bracket to get for one of these? Considering the lens in question, I'm trying to avoid a solution that will cost more than the lens itself.
09-16-2018, 07:12 PM   #2
Here is a past post, using a Q. I used the same arrangement for my A 300/f4 with my K5 and it works very nicely.I see that the parts link is not active, so try this...
09-17-2018, 08:49 AM   #3
" problem is their tendency to flex. "
No it is not because it was designed to resist the buckling effect of the lens material used.
Support bracket sometimes you don't want to carry bulky objects.. see whitehouse journalist.. carry only camera with a large lens without support... follow them.
bracket, camera, lens, lens support bracket, pentax help, photography, support, troubleshooting
Lens Support When Adapting MF Lenses to FF reivax Pentax Camera and Field Accessories 10 01-05-2018 11:16 PM
L Bracket With Ball Head or No L Bracket C_Jones Pentax Camera and Field Accessories 8 01-04-2016 05:02 AM
K-5 will not turn on - Pentax Support advice carrrlangas Troubleshooting and Beginner Help 2 01-10-2013 11:02 AM
The K-X and K-7 support PTP - Doesn't PTP support tethered shooting? Russell-Evans Pentax DSLR Discussion 2 12-25-2009 10:04 PM
All times are GMT -7. The time now is 09:52 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
