Originally posted by pschlute You are missing the fact that on the Pentax flash units HSS is a P-TTL mode only. You cannot use HSS and manual flash output together.
Thank you pschlute, that's exactly what I was missing. Is this the norm on other flash systems as well or is this a Pentax thing?
Originally posted by Class A If you are desperate to use HSS and manual flash power control in combination, you could get two Cactus V6II triggers and remotely control the flash power from the camera. The flash would remain in P-TTL mode, thus would keep supporting HSS, while the V6II trigger on your camera would give you manual control, or P-TTL as you desire.
Thanks Class A, I have three V6II triggers on their way from B&H so I should have that capability. I really thought it would have been something available on the camera though
