09-26-2018, 08:22 AM   #1
SMC Pentax-F 50mm F1.7 auto focus issue on K1 M2
Everytime when I put SMC Pentax-F 50mm F1.7 on k1 m2, this lens can not auto focus. I must turn the aperture ring from "A" to 1.7 and then turn it back to "A". After that auto focus started working.
I do not understand why. Is this lens just working like this? Or maybe I can change the setup on the camera to let auto focus work right away?
Thanks.
09-26-2018, 08:34 AM   #2
Not a Number's Avatar
The contacts probably could stand a cleaning. Try wiping them down with a microfiber cloth. Pay particularly close attention to the "data" and "A". The data pin corresponding to the 6 o'clock position of the camera face. The "A" should stick out a bit more than the other pins. It may retract a bit when you take the ring off the "A" setting and pop out a bit in the "A" setting. The pin might be a bit sticky so it doesn't pop out when you first mount the lens. Changing the ring setting might give it the nudge it needs to pop out. A tiny dab of alcohol or lighter fluid applied and immediately removed with a cotton swab might do the trick on cleaning away the stickiness.
09-26-2018, 09:20 AM   #3
Otis Memorial Pentaxian
I agree that this is probably a contact issue. To expand on @Not_a_Number 's excellent advice, the camera attempts to detect the "A" contact followed by the "data" contact. If either is dirty or not functioning properly, AF will not work.
09-26-2018, 09:24 AM   #4
Maybe the lens contact pins is not well aligned to the camera body. Try turning the lens a little bit left of A settings, if auto focus works , then turn a little bit of right if auto focus works... whichever.
50mm, 50mm f1.7 auto, auto, auto focus issue, camera, f1.7 auto focus, focus, issue on k1, m2, pentax help, pentax-f 50mm f1.7, photography, smc pentax-f 50mm, troubleshooting
Looking for Ricoh WG-M2 firmware gedasst Pentax Compact Cameras 3 05-08-2018 03:20 AM
For Sale - Sold: Ricoh WG-M2 4K Action Camera Mikesul Sold Items 4 11-15-2017 11:54 AM
SMC Pentax A f1.4 50mm VS SMC Pentax M f1.4 50mm plunkstar Troubleshooting and Beginner Help 30 12-31-2015 09:04 AM
[Asking]SMC Pentax K 50mm f1/4 VS Pentax-M 50mm f1.4 VS Pentax-M 50mm f1.7 ? liemjerry Pentax SLR Lens Discussion 29 07-08-2015 04:23 PM
All times are GMT -7. The time now is 01:02 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
