Originally posted by SharkyCA could be camera shake BUT not dust
i think he ws saying you have dust on the sensor which is visible in both pictures. But this is a side issue, nothing to do with the AF
I suggest you stick to the focus chart to determine if you have a focus problem. reset the camera to 0 adjustment and redo the test. You will need to take about 10 shots, each time moving the focus ring between shots, you want to make the camera
work to acquire focus. A single test is not enough, camera AF is not that consistent. let us know what you see in those 10 pictures.
Then do a test by focussing on a distant object such a brick wall. Do 10 tests again. This wont show up any FF/BF but it will show if your camera/lens is capable of achieving focus at all.
