Show Printable Version 4 Likes Search this Thread
10-04-2018, 02:47 PM   #16
Also take a head whose size roughly matches that of your tripod.
Thanks for such considered advice.
The velbon base has a circumference of 5".Whether the ball is 54mm or smaller seems like it will fit. I'm a bit worried a really small head would look disproportionate.
In UK import duties make many of the suggestions quite a bit more expensive than in USA. An exception is benro, I can get benro b2 for £77 and it seems to meet your criteria. It's got friction control, separate drag adjustment and lock knob, and 40mm ball. PU-60 qlr plate and 5" head.
No one on the thread has recommended them yet, so it's less appealing despite the high specification.
Lots of recommendation for Sirui and as it's not a lot more I may go for one of these, the k40x is £99 excluding duty.
10-04-2018, 03:24 PM   #17
I found the Neewer Gimbal head for my wife. On Ebay for $60.00. Am well pleased with the quality out of the box, too soon to say how it will perform long term. A gimbal requires a level tripod. In that respect it works much like a pan and tilt as it does not allow all the angles of a ball head. Arca Swiss is the way to go, it is easy to adapt an Arca clamp to any head.
10-04-2018, 03:31 PM   #18
Billk's Avatar
My heavy tripod has a joystick on it. Very versatile.
My lightweight tripod has a ball head on it. Stable and compact but useless for moving subjects IMHO.
10-04-2018, 04:39 PM   #19
cmohr's Avatar
Just make sure whatever brand you go for in a ballhead, make sure it has a separate pan adjustment, so as you can get the angle right on the ball section, but still pan freely.
10-04-2018, 05:40 PM   #20
I would go with an Arca compatible head. BUT you should also consider getting an L bracket. Modern cameras with their polywhatever bases do not grip very well to tripod heads and your camera tends to move on the head in portrait position and, if nudged slightly, in landscape. My K3 and Nikon D610 are both less secure on my tripod than my old beast of a camera, my Bronica Etrs.
10-05-2018, 05:15 AM   #21
bdery's Avatar
QuoteOriginally posted by Patricia1066 Quote
I hear that Benro is ok, especially their newer heads. Some older stuff isn't as well regarded.
The K40x is huge. Really huge.
Let's put it this way : I use a K-1, 60-250 on a K10x head and it does not come close to reaching its limit.
Except if you regularly use an ultra-tele (in which case a gimbal would be better) you'd be well served with the K1-x or K20x at most.
10-05-2018, 03:47 PM   #22
Review here which slates the benro b0 head, even a kit lens caused creep as the b0 just couldn't support camera and lens safely.
Review: Benro Travel Angel A-1691TB0 - The Phoblographer
Probably will get the sirui k10x
10-07-2018, 06:47 AM   #23
I chose the Neewer ball head, 360 panoramic and Neewer L plate.
All the suggested criteria are met, and I'm happy with the security of the camera using the supplied plate.
I also bought the Neewer L plate. This isn't compatible with the ball head unfortunately, and is currently secured with a rubber band which gives necessary grip to the clamp.
The quality of the ball head is very good, and the knobs provide effective control of the ball movement.
The L plate is very well finished, and can be fitted to the K5 leaving access to the battery and card slots.
Total £26 for both.
camera, pentax help, photography, price, range, tripod, tripod head, troubleshooting
Misc Please help me choose photos for this year's fair Craigbob Post Your Photos! 16 06-11-2018 05:59 PM
Need help figuring out tripod and tripod head for k3 II Infinite Ascension Troubleshooting and Beginner Help 32 03-27-2018 07:05 PM
Help Me choose a better Pentax Camera,Please. Dean1966 Troubleshooting and Beginner Help 22 02-05-2018 02:52 AM
Help me choose tripod for K3 kref Pentax Camera and Field Accessories 10 10-15-2014 06:07 PM
(And yet another) Help me choose between this 3 tripod legs carrrlangas Pentax Camera and Field Accessories 9 02-21-2014 04:11 PM
All times are GMT -7. The time now is 08:43 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
