10-08-2018, 07:04 AM   #1
Problem with removing top cover on spotmatic
I have been trying to remove the top cover of my Spotmatic. However, as shown in the image, the cover under the rewind knob would not budge at all. I have tried using lighter fluid and even lubricant. I was informed that it requires a spanner wrench but the scratches on the finish(which I truly regret) have been all from it. It is very frustrating for me and I would truly appreciate any help or piece of advice. Thank you in advance.
IPhone 7  Photo
10-08-2018, 07:45 AM   #2
Just1MoreDave's Avatar
My first thought is it's a left hand thread.
10-08-2018, 07:46 AM   #3
Not a Number's Avatar
QuoteOriginally posted by Just1MoreDave Quote
Reverse threading is often the case on rotating parts.
Try applying heat with a soldering iron.
Try tapping around on the retainer gently with a flat punch and hammer. A cheap flat bladed screwdriver might do in a pinch.
Try tapping the end of the connecting bar on the spanner with a hammer to turn the retainer.
Try penetrating oil - take care with the amount and clean up after allowing it to penetrate and after (hopefully) removing the retainer.
10-08-2018, 07:54 AM   #4
Link to service manual>http://www.pentax-manuals.com/manuals/service/spotmatic_sm.pdf
10-08-2018, 08:54 AM   #5
Otis Memorial Pentaxian
QuoteOriginally posted by JohnX Quote
Also...
http://www.pentax-manuals.com/markroberts/nat_cam_spii.pdf
...has instructions on disassembly.
Google also suggests:
How to Open a Spotmatic
Spotmatic Disassembly
The fitting you have been working on is right-hand thread, but perhaps needs a little penetrating oil. Worst case is someone having applied lacquer or thread lock. In that case, a solvent might be needed.
camera, cover, pentax help, photography, spotmatic, top cover removal, troubleshooting
Need photos of K-3 with top cover removed klh Repairs and Warranty Service 13 10-11-2018 12:53 PM
How to replace broken glass cover on the top lcd on my k-3ii blb511 Pentax K-3 3 03-01-2018 06:44 PM
replace broken glass cover on top lcd setting display blb511 Troubleshooting and Beginner Help 4 02-16-2018 08:54 AM
TOP 10 compact DSLR. So what according to you are the TOP 10 compact APS-C and FF? SunnyG. Pentax DSLR Discussion 16 06-26-2017 12:02 PM
Removing top on ME Super annakarin Pentax Film SLR Discussion 2 05-10-2014 03:27 AM
All times are GMT -7. The time now is 06:21 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
