Show Printable Version 13 Likes Search this Thread
10-22-2018, 10:59 AM   #1
Kp or K3II
I have a Pentax K50, but i thought of upgrading... Kp or K3II? What you guys say?
10-22-2018, 11:14 AM - 1 Like   #2
Both are substantial upgrades over the K-50. I would generally recommend the KP over the K-3 II for its better image quality (newer sensor + image accelerator). It also uses the same battery as the K-50, so you'll be able to re-use the one you already have.
The K-3 II is faster (in terms of burst rate and buffer), has a larger battery, and has GPS, but it uses an older sensor which is a bit more noisy. In most other areas, the KP and K-3 II are the same. If you've been happy with the K-50, go for the KP.
Pentax KP Review - Introduction | PentaxForums.com Reviews
Pentax KP vs. Pentax K-3 II vs. Pentax K-50 - Pentax Camera Comparison - PentaxForums.com
10-22-2018, 11:17 AM   #3
Agi
Both are substantial upgrades over the K-50. I would probably recommend the KP for its better image quality. It also uses the same battery as the K-50, so you'll be able to re-use the one you already have.
I forgot to say, I'm a portrait photographer, I shoot specially outside in the street.
10-22-2018, 11:19 AM - 1 Like   #4
QuoteOriginally posted by Agi Quote
Probably the KP then. Maybe pair it with a juicy portrait lens like the new D FA* 50mm?
10-22-2018, 11:26 AM - 1 Like   #5
UncleVanya's Avatar
I went from K-50 to K-3 when the K-3II was an option also. The K-3 (like the KP) offers an onboard flash. The K-3II has an onboard GPS rather than flash. I suspected (and still think) the onboard flash is more useful to me. I do miss the Pixel Shift features for landscapes. As for the KP - I have never used it. I do however like the battery life of the larger battery more than I liked the battery life in my K-50 - but this is a MINOR issue.
The larger benefits were moving from 12 bit to 14 bit raw, moving from 16mp to 24mp, improved autofocus, improved metering, etc. The larger buffer and higher frame rate were also beneficial in niche situations.
The KP unlike the K3ii offers the accelerator chip for improved high ISO output. The KP like the K3ii offers a battery grip - the grip uses the larger battery which means managing two types of batteries for the KP if you want to use the grip.
Finally from what I have read the KP grip - despite being available in 3 sizes - is not loved like the K-3/K-3ii/K-70/K-50. If you love the grip on the K-50, the K-3ii is likely just up your alley.
---------- Post added 10-22-18 at 02:28 PM ----------
The smaller KP may make the most sense then. I'm a fan of the K-3 ergonomics but the size isn't the best for street (although it isn't terrible at it either). For Street Portrait work the DA 40 is my favorite - very short and not intimidating. The DA 70 is another option that is diminutive also.
10-22-2018, 11:35 AM   #6
Agi
I see, well I do not think the grip is going to ,be a huge problem since my hands are pretty small hehe.
10-22-2018, 11:37 AM   #7
Agi
Didn't think about the combination of the DA 70 with the KP, I think i will probably give it a try.
10-22-2018, 11:59 AM - 1 Like   #8
If you are street shooting, the KPs flip screen should also make it easier to shoot from the hip.
10-22-2018, 01:15 PM - 1 Like   #9
If you don't need the bigger buffer, go for the KP, I keep reading about big and small features that I wish my k3ii had (bought it before the KP was released). Such as night mode and bulb timer.
10-22-2018, 01:18 PM - 2 Likes   #10
mike.hiran's Avatar
FYI, the KP battery grip lets you use the K5 type battery OR the KP battery (which is awesome). The grip has made the KP a much improved camera from an ergonomic point of view - I liked it quite a lot without, but with, it's fantastic. And the flippy screen would be very helpful for street IMO (I don't do much street, but I do know from event photography, having a cam up to your face can be a dead giveaway. Taking pics from live view, focus peaking, and using the live view zoom helps a ton. By the way, I've been shooting in RAW+jpeg so I can tune the cam to a contrasty black and white (saved as jpg) and the RAW comes with all color info so I can do whatever. The view on the back screen is B&W in live view, so that could be a minus depending on your priorities.
Also, I think the KP is slightly quieter than my K3 (I don't have a k3ii) so that could be good too. And add to all this the KP has 5 axis stabilization for camera at your waist or shoot-and-run shots and I think the k3ii has 3 axis. And the 3rd control wheel on the KP comes in handy at times too.
They're both great cams, but IMO, if you're not doing lots of action (where having a big buffer would help) or lots of astro, the KP fits the bill for street a bit better.
10-22-2018, 02:26 PM - 1 Like   #11
I have the K-3 II. It does an excellent job. I recommend it.
10-22-2018, 04:25 PM - 2 Likes   #12
Digitiser of Film
BigMackCam's Avatar
I have both the K-3 and K-3II. I like the on-board flash of the K-3 (although I barely use it), and don't use the GPS in the K-3II at all. For me, the K-3 is a slightly more useful camera, but they're more-or-less equal. Both are absolutely fantastic cameras in every respect. The KP offers better high ISO signal-to-noise, though some of this is due to noise reduction in the image capture hardware chain. For most users, that won't really matter, since the end result is generally better performance at high ISO settings. Personally, I like the "flagship"-level build quality and size of the K-3 / K-3II over the KP, and the dual card slots (one of my favourite features in terms of "peace of mind"). But the articulating screen of the KP is genuinely useful and something that I hope the K-3II's successor will have. Battery life on the K-3 / K-3II is better than the KP.
Personally, even though the KP offers better high ISO capability, I'd still pick the K-3 or K-3II in preference if shooting raw files (and I'm a high ISO nut ). But both cameras are outstanding
10-22-2018, 05:12 PM - 1 Like   #13
For portrait/street the KP. Tilting screen, 10% lighter than K-3ii, 5-axis SR, on board flash for emergency fill-flash situations.
10-22-2018, 05:24 PM   #14
Where are any new K-3 II bodies for sale in the states? Last I saw was the silver version at Adorama which are gone.
10-22-2018, 11:47 PM   #15
Agi
What you think about AF?
battery, camera, flash, grip, k-3, k-3ii, k-50, k3ii, kp, onboard, pentax help, photography, street, troubleshooting
KP vs K-70 - to KP or not to KP, that is the question OldChE Pentax DSLR Discussion 28 11-02-2019 05:29 AM
Help me think... K3ii or KP or M43 or... mgvh Pentax DSLR Discussion 37 07-06-2018 07:25 AM
Jump from K3II to KP? Paulo Pentax DSLR Discussion 20 11-30-2017 09:54 AM
Katzeye-Focus-Screen for Pentax KP,K3II,K3,K-5IIs,K5II,K5,K-7,K-30,k-50,K-500 turkiye2turkiye Pentax Price Watch 5 10-03-2017 03:31 PM
Would you step up from your K3II to the KP if not WHY??? Gold Coast Pentax K-3 & K-3 II 32 08-09-2017 07:08 AM
All times are GMT -7. The time now is 05:43 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
