Originally posted by ghigoblin after a few shot it seems that it'all fine.
I had a similar issue with my Rokinon 85mm f/1.4 (made by Samyang).
The lens worked perfectly when I first got it, but gradually the aperture lever started to stick in the wide open position. It eventually got so bad that I had to take the lens off after every shot, tap the aperture lever to unstick it, then remount the lens for my next shot.
It felt like a friction problem, so I figured that it might eventually work itself out, and that's what happened: the aperture lever started sticking less and less, and now it doesn't stick at all anymore. The lens is working perfectly now (several hundred exposures with no problems).
