Originally posted by Oldseabee ...lens has a couple of adapters with it...
TLDR version, educated guess that the rear is M35 threads and there are no other adapters.
I'm always curious about telescopes.I looked at the auction photos and see these parts:
- Telescope, with unknown threads on back.
- Case
- Diagonal for optical viewing. A black part with "Meade" and "Japan" printed on it.
- Finder scope. Mostly white part with "5 x 21mm" printed on it. A 2nd photo of it has "Japan" on the opposite side".
- Eyepiece. "MA25mm". The auction text mentions a 2nd eyepiece.
I'll
assume the eyepiece and diagonal are 1.25" standard. M42 or T-threads (T is also 42mm wide, but different thread pitch than M42) would therefore be wider than the diagonal is, so the threads on the back of the scope must be narrower than 42mm. If the back of the scope is 42mm then there's possibly a missing adapter to go from the back of the scope to the diagonal but that would be weird product engineering.
I emphasize that this is guesswork, but I strongly suspect that the threads are narrower than M42 or T.
Here's a discussion of a similar telescope which may or may not be the same exact model in the auction. The original poster describes the rear cell as 1.375" or 35mm.
Meade 1000mm f 11 Mirror Lens
Let's assume the M35 rear thread. You could use an M35 to T-thread adapter, then possibly a T-extension to reach focus when the diagonal is not in the optical path. Or maybe this one piece will work; I don't see thread specifications in the description by I think many ETX scopes are M35. High Point Scientific support is great, so if you win the auction measure the threads, then contact them.
Meade 64 T-Adapter for ETX 90-125 Telescopes - 07363
Good luck with the auction.
