11-10-2018, 10:25 PM   #1
Pentax O-ICK1 gel stick and IBIS
Hi all
I have a Pentax O-ICK1 which I'm planning to use to clean some stubborn bits off a micro four thirds camera (Panasonic GX8). However, I've read on occasion that other gel sticks like the Eyelead ones can be very sticky and take some force to remove, thus potenially damaging the IBIS mechanism. My plan was to use it with the camera on as this should prevent the IBIS mechanism from being able to move around.
With that in mind, would it still be OK to use? I would assume the Pentax SR and other IBIS systems would all be fairly similar?
If anyone has used both the Pentax and Eyelead gel sticks, how do their 'stickiness' compare?
Thanks
11-11-2018, 06:02 AM   #2
Iíve used the O-ICK1 a couple of times with my K-01 and K1 with no problems.
I didnít notice it requiring much force to remove.
I will note the stick is marked for the Pentax flange distance so you know when youíre about to hit the sensor, and that visual aid wonít work with the Panasonic...
-Eric
11-11-2018, 07:31 PM   #3
david94903's Avatar
The O-ICK1 works great on any sensor. But the level of adhesion to the sensor can be a bit nerve wracking the first time through. I'd recommend a good stiff drink before and after, just to settle the nerves, LOL!
camera, gel, ibis, mechanism, o-ick1, pentax, pentax help, pentax o-ick1 gel, photography, sticks, troubleshooting
About IBIS - Which company started IBIS in DSLR's ? Curiosity question. jpzk Pentax DSLR Discussion 30 06-13-2019 04:56 PM
Sensor Gel Stick on Pentax K-1 kthornsberry Pentax K-1 14 12-14-2017 06:30 AM
Sensor Gel Stick for 645z Primus Pentax Medium Format 9 05-22-2015 06:04 AM
Nature Ibis, Ibis, everywhere photolady95 Post Your Photos! 9 05-11-2011 08:38 AM
Pentax O-ICK1 Cleaning Stick/Artic Butterfly bsudrew Pentax DSLR Discussion 12 01-29-2011 10:30 AM
All times are GMT -7. The time now is 09:51 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
