Good morning gentlefolk!
Recently got a K50 (about 6 weeks back) and quickly discovered the Catch-In Focus (CIF) while using a KA-mount Miranda lens that I grabbed on ebay for £5.
The lens has automatic aperture control ("
A" setting on the aperture ring) but everything else is manual and works great with CIF.
Emboldened by this discovery, I then purchased a much larger Sigma 75-300mm lens at £10 in an antique store. This lens is
entirely manual - (lacks a "
A" setting on the aperture ring) - and as such has the barest K-mount imaginable - no contacts whatsoever.
Now, what is interesting about this is that CIF no longer works on it - as soon as I hit the shutter release, it takes a photo (whereas, with CIF enabled and working, it would hold off until focus was achieved).
It actually does this (allows a shot to be taken) even if there is no lens attached to the camera body, and focus-priority is enabled - which makes me wonder if a certain combination of shorted/open contacts may permit the CIF to function?
Incidentally, I can still use this particular lens by waiting for the focus-confirmation on the viewfinder/screen, but, I rather
like the convenience of the Catch-In Focus!
So my questions are as follows:
- Is there a setting that I am missing that allows CIF to work with this fully manual (PK mount) lens?
- If not, can the lens be modified to allow the caamera to use CIF with it?
- If not, what is the minimum spec required for CIF to work? Is a KA lens the minimum?
