11-26-2018, 09:27 AM   #1
Samyang 24mm 1.4 decentered?
Hello, recently I have bought Samyang 24mm 1.4 for my K-1 but since the first shot, I thought there was something off about it. I'm uploading few test corner crops (shot from a tripod, same distance, settings, focus), can any other users of this lens say if that kind of performance is to be expected from this glass or my copy is a dud? I am curious to hear your thoughts.
Best Regards.
11-26-2018, 09:30 AM - 1 Like   #2
Looks like an exchange would be warranted for this copy. Samyang lenses do suffer from poor quality control, but once you get a good copy you should be pleased with the results
11-26-2018, 10:11 AM   #3
Thanks for the reply, I guess I will return it, hope the next one will perform better.
11-26-2018, 11:50 AM   #4
Yeah, your copy is a dud. Exchange it and there's maybe a 50% chance of the next one being good. A properly assembled copy should be quite good but it's difficult to find one.
The 24/1.4 seems especially prone to assembly errors. This applies whether it's labeled Samyang, Rokinon, or Bower. All 3 companies come form the same factory.
I'm curious what the center of your bad copy looks like. My 2 bad copies were bad in the center as well as the corners. It seemed like something more significant than typical "decentering".
11-27-2018, 01:29 AM   #5
QuoteOriginally posted by DeadJohn Quote
Actually, about center, at f1.4 it is impossible to find a perfect focus (low contrast doesn't help), it either goes into magenta or into green. It improves a bit stopped down. Quick crops attached.
11-27-2018, 10:20 AM - 1 Like   #6
^ your copy is even worse than my 2 bad copies were.
All these bad copies make we wonder just how widespread the problem is. Are there a lot of good copies on the first purchase that people just don't post about? Or do a lot of Samyang/Rokinon buyers not notice the problem until it's too late to return a bad lens? Or does Samyang accept a high level of returns as the cost of doing business, and still makes a profit despite all the bad copies?
...just wondering, Samyang will never release data, and anything compiled via PF will be anecdotal.
11-27-2018, 11:24 AM - 1 Like   #7
Journeyman Cat Wrangler
SSGGeezer's Avatar
Sad to see but when it is good, it can be an amazing lens. Here is one from my get together with @jcsntc at dawn last Friday. https://www.pentaxforums.com/forums/members/50522-jcsnyc/albums/12857-pemaqu...ure121199.html
11-28-2018, 05:14 PM - 1 Like   #8
SSGGeezer - I took a quick look at your link, huge difference, no way I could have achieved that kind of sharpness with my copy. I sent it back today, hopefully next one will be better.
12-04-2018, 04:40 PM   #9
QuoteOriginally posted by Higaide Quote
Hello again, just thought I would share - today I received another Samyang 24mm 1.4, and I am having a hard time telling which one is worse, the one I sent back or the one I just received. To sum up - turns out the first one really had a focusing issue (what I mentioned about focus immediately shifting from green to magenta). Second one doesn't have that issue, no problem focusing in the middle of the frame however there is something else... bottom right part is so out of focus i didn't even need to pixel peep to see the problem (see crops). There is also an issue with focus ring making excruciating noise while being turned, becoming louder when nearing the infinity range. I think I'm done with Samyang, hopefully Pentax will realese something in the near future with wide aperture and covering 24-28mm range... (unless there is already an alternative that I missed?)
12-04-2018, 05:03 PM - 1 Like   #10
clackers's Avatar
Yep, just send that one back, too, and keep doing it until you get what you paid for, Higaide.
My advice to everyone buying a lens from any company is to test it like you have before throwing any of the packaging away.
24mm, camera, corner softness, decentering, pentax help, photography, samyang, samyang 24mm, samyang 24mm f/1.4, shot, troubleshooting
Decentered Lens ? Or misfocused Meg4mi Troubleshooting and Beginner Help 13 12-28-2017 09:47 AM
Samyang 24mm F1.4 V DFA 24-70 at 24mm BarryE Pentax SLR Lens Discussion 3 10-29-2017 02:03 AM
Is this lens decentered? Rokinon 10mm Blueberrybob Pentax SLR Lens Discussion 14 09-07-2017 05:22 PM
What lens is decentered if decentered at all? Medex Pentax SLR Lens Discussion 11 08-23-2017 01:59 AM
Decentered Tamron 28-75 f2.8 Lens ikiyuz41 Pentax SLR Lens Discussion 2 01-07-2017 05:40 PM
All times are GMT -7. The time now is 10:50 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
